ECU QUESTION
ECU QUESTION
Postby DCha10 » Wed Jan 17, 2018 4:23 pm
Can anyone tell me what the last 2 letters on the ECU are for?
Are they interchangeable so to speak?
Mines CC11-12A650-AB and has been declared knackered thru water damage..
Have found another but the last 2 letters are "AC" but everything else matches.
Its not really a £350 gamble i want to take if its not correct.
Thanks in advance
DCha10
Re: ECU QUESTION
Postby knobby1 » Wed Jan 17, 2018 8:03 pm
The last two letters usually denote the "revision status" or latest update etc...AA ...AB ...AC etc.
Re: ECU QUESTION
Postby adam75pl » Wed Jan 17, 2018 8:39 pm
DCha10 wrote:Can anyone tell me what the last 2 letters on the ECU are for?
Thanks in advance
£350?
I paid less than £150 for mine when decided to do my cruise...
Still have the old one somewhere...
This post only expresses opinion of the author of today. It can not be used against him tomorrow, or any other day following that date. In addition, the author reserves the right to change his views, without prior notification.
T280 SWB 2.2 115PS
adam75pl
Re: ECU QUESTION
Postby loot » Thu Jan 18, 2018 12:05 am
Thanks in advance
£350?
Cruise is bcm not pcm :-)
I always say the first is spec and second is revision. But you'll do an initialization pmi so the data from your original should be loaded to it
Ids map here
loot
Re: ECU QUESTION
Postby adam75pl » Thu Jan 18, 2018 5:11 am
loot wrote:Cruise is bcm not pcm :-)
I’ll get my coat...
T280 SWB 2.2 115PS
adam75pl
Re: ECU QUESTION
Postby andz327 » Thu Jan 18, 2018 5:38 am
Average price is around £120 mark, I'd be looking elsewhere if i was you mate
andz327
Re: ECU QUESTION
Postby davyjcb » Thu Jan 18, 2018 2:30 pm
Bridge van do an ecu kit bcm,pcm an a key for 75 plus the vat provided that they give you the correct setup that matches your van and you don't mind the wrong chassis no on your modules it will run ok
If you do go down this route you should do pump& pilot learns /injector cal no's as these values are held on the pcm
96 escort 55 van gone
98 smiley mwb semi high gone
01 90/350 mwb semi high roof gone
05 135/350 lwb semi high roof gone
10 85/260 swb low roof leader gone
09 140/350 lwb semi high fwd
11 115/330 mwb semi high roof
davyjcb
Re: ECU QUESTION
Postby DCha10 » Sat Jan 20, 2018 10:32 pm
Thanks for the reply’s...
Anyone selling one to fit my transit? 2012 model the only one I found on eBay that looked the same with the above mentioned numbers is the £350 all the others are a different looking ecu with completely different numbers
DCha10
Re: ECU QUESTION
Postby DCha10 » Sat Jan 20, 2018 10:47 pm
https://rover.ebay.com/rover/0/0/0?mpre ... 2999499408
This is the only one I’ve found which is close
DCha10
Re: ECU QUESTION
Postby paul2012 » Sun Jan 21, 2018 6:43 am
DCha10 wrote:https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F272999499408
CC11-12A650-AB is for mk7 2.2 Euro 5 engines :wink:
CC11-12A650-AC will fit. BUT it will require to be reprogramed to your mk7 :!:
They are NOT plug & play. Even if you get one with matching part no.
Every van has different / optional features. It still require programming to your van. :wink:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Re: ECU QUESTION
Postby loot » Sun Jan 21, 2018 10:06 am
Modules after 2010 will start getting tricky Paul because of the e4 and e5 changeover and also 2012 etis coded/incodes changeover too.
I would hope that cc11 means it is incoded access and eg. Bk21/Bk31 denotes custom and mk8?.
Any info that can be added to help the home user would be cool.
:wink:
Ids map here
loot
Re: ECU QUESTION
Postby DCha10 » Mon Jan 22, 2018 4:46 pm
I know it will require reprogramming but was just making sure if i buy it and get it reprogrammed its going to work.....This van has been a pain! should have stuck with my faultless MK6.
DCha10
Re: ECU QUESTION
Postby DCha10 » Wed Jan 24, 2018 3:35 pm
Apparently the last 2 letters make no odds
But the 4VFB and S180145001 B are what matters...
So if anyone has one for sale or can point me in the right direction that would be great..
DCha10
Re: ECU QUESTION
Postby paul2012 » Thu Jan 25, 2018 4:54 am
DCha10 wrote:Apparently the last 2 letters make no odds
Incorrect.
PCM part number is irrelevant. As it changes every time PCM gets updated & the new label never gets printed of & attached to PCM :roll:
4VFB is know as "tear tag" & Tear tag or PCM part number can be used for programming PCM with correct calibration for the vehicle it's fitted to .
Again that's irrelevant. As you are replacing PCM for a second unit & then programming it to your vehicle.
There for you can use either the tear tag or part number from you old PCM to program the second hand replacement unit via IDS.
Or you could simply use "As built Data"
Replacement PCM for your van as it's Euro 5. Should be SIEMENS / Continental & have SID 208 on the label. :wink:
paul2012
Re: ECU QUESTION
Postby DCha10 » Tue Jan 30, 2018 12:32 pm
Thanks for the reply!
DCha10
