running out of fuel
running out of fuel
Postby 4x4 tranny » Fri Jan 19, 2018 1:26 am
hi guys
had a quick hunt through here but cant find my problem, so here goes.
well after building camper went for drive gauge was on 1/4 full, but my luck ran out of fuel at a set of lights,
got a mate to get and bring some fuel, while waiting RACQ, road side assistance stop ask if I was a member na, told story he said ""well been sitting so long floats can jam"" , ok under stood.
end up getting it going bleed at injectors and went to garage.
well just been away and bugger me dead tank 1/4 full thinking should fill up and the bloody thing ran dry again. was lucky to get tow home check tank its 1/4 full. so gather pick up to high in tank.
took sensor out and tanks 1/4 full but pickups in fuel not much I must admit but is in fuel.
but still wont start.
ok any ideas?????
thanks in advance.
4x4 tranny
Re: running out of fuel
Postby Jim Archer » Fri Jan 19, 2018 10:28 am
Petrol? Diesel? Model? Age?
Hole in dip tube, lift pump, and airleak at fuel filter spring to mind.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby 4x4 tranny » Sat Jan 20, 2018 1:46 am
ok, thanks Jim,
Got tank out today but wont be able to check things till Monday.
Had quick look and sure enough there's at least 20 litres if not more still in tank, but will have to wait till after weekend to check further.
will keep you up to date.
did hear there maybe a restart program to reprime, anyone know this is the fact? like turning the key off an on 8 times?????
4x4 tranny
Postby 4x4 tranny » Sat Jan 20, 2018 1:48 am
sorry its a Mk 6 2004 VJ diesel 2.4
4x4 tranny
Postby ned » Sat Jan 20, 2018 2:52 am
Turning the key 8 times is to program the remote central locking :wink: N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby 4x4 tranny » Sat Jan 20, 2018 5:15 am
cool thanks Ned,
Learn something new ever day ...lol
4x4 tranny
Postby ford downunder » Sun Jan 21, 2018 12:06 am
Hey, had the same problem with my VJ 2004 , turns out the housing where ya fuel filter screws up to was porous and sucking air through the casting , apparently common problem ,i replaced the housing and has'nt missed a beat , but get an injector place to check it out for you they can hook it up to a pressure system and dunk it in a tank and watch for bubbles , Hows QLD :)
ford downunder
Postby 4x4 tranny » Sun Jan 21, 2018 2:14 am
mmmm thanks for the advice now tanks out ill check that end as well, but will get it checked when re assembled.
ya a bit hot up here 36deg where I live but not as hot as the south at the moment see it 42deg in Melbourne an 65 deg on the AO tennis the other day ............now that's bloody hot....lol
4x4 tranny
Postby ford downunder » Sun Jan 21, 2018 5:00 am
Yeh not sayin that's the prob but it was something that we had go wrong , Ive had the van since new she's done 420k so I've had a few intimate moments with it and been chasing my tail a lot and there's always somthing else that ya didn't think of
ford downunder
Postby 4x4 tranny » Sun Jan 21, 2018 10:42 pm
right, so I wonder how many intimate times I'm going to have with this one....lol
first one I've owned. hope to be able to got 400ks out of it with out to many intimate moments hahaha
4x4 tranny
Postby ned » Sun Jan 21, 2018 10:47 pm
Have you checked the fuel pick up pipe in the tank for splits, holes ect. N
ned
Postby 4x4 tranny » Mon Jan 22, 2018 10:46 am
yes Ned
have had pickup float centre out of tank, checked pickup lines couldn't find any cracks splits etc,
Also check float, wiring etc.
am hoping to try and prime fuel directly from tank to container then next step is to remove filter and see if the pump will pull fuel through to there.
if no improvement as ""ford downunder"" says be replacing filter housing.
will be reporting.
oo ya does anyone know if there's a low fuel warning light on these vehicles ? I don't seem to be able to find one?
4x4 tranny
Postby ford downunder » Mon Jan 22, 2018 12:49 pm
Hey , the 2004 VJ has a fuel bouser symbol that comes on when you get low , it' comes on near the speedo somewhere around there , don't get a gut full of fuel sucking on those pipes
ford downunder
Postby 4x4 tranny » Mon Jan 22, 2018 10:14 pm
no mate have a we primer pump been there done that....lol not nice.
4x4 tranny
Postby 4x4 tranny » Tue Jan 23, 2018 1:14 am
ok figure this one out...
primed fuel from tank to container direct , no problems good flow etc.
connected fuel lines to electric, pump turned key on an pump primed, no problems as all. cracked injectors and in two turns had fuel. done injectors up and it started,
have added no extra fuel to tank, and gauge still on 1/4 full, also did notice low fuel pump on dash on start up first time I've seen it.
so got me stuffed...lol
going for drive soon but its been idling for an hr now with out any fuel added before it stopped.
4x4 tranny
