2009 (59) MK7 Transit 2.4 RWD 115 - White Smoke
Re: 2009 (59) MK7 Transit 2.4 RWD 115 - White Smoke
Postby ned » Mon Feb 19, 2018 11:27 pm
Quick question, does it only smoke on a cold engine? N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Click4 » Wed Feb 21, 2018 2:29 pm
Yep new bolts, washers (Genuine) and clamps
Even tried tightening them down a little more.
It was initially smoking intermittently on startup but a quick rev and it went away.
Now it’s become permanent.
Found 2 things though today.
EGR cooler is leaking internally. And injector 1 is under isn’t fuelling correctly so ecu is ramping the fuel up then seeing its fuelling too much and drawing it back in on cylinder 3 to even out engine idling. Maybe injector is not atomising correctly.
Click4
Postby Click4 » Wed Feb 21, 2018 2:31 pm
Don’t know why it’s flipping the photos :S
Click4
Postby knobby1 » Thu Feb 22, 2018 8:38 pm
So it's not smoke, it's steam...as evidenced by your leaking EGR cooler. By-pass the EGR cooler, take her for a decent run and see if the steam/smoke disappears.
Postby Click4 » Sat Feb 24, 2018 5:40 pm
Seems to be, but it smells of diesel because of the iffy injector over fuelling
Click4
Postby knobby1 » Sun Feb 25, 2018 6:46 am
Click4 wrote:Seems to be, but it smells of diesel because of the iffy injector over fuelling
Well the EGR cooler is obviously leaking, so I would sort that first, then worry about the injectors after that.
Postby Click4 » Tue Feb 27, 2018 6:42 pm
EGR cooler done,
Had been bodged previously.
Looks like some kind of epoxy was used on it.
Fitted new one which has sorted that, damn thing is still smoking though, not as bad but still bad lol
Van is costing a fortune, everything I touch to try and diagnose the fault I find something else, had to put a new hose on egr Cooler also because the rubber had gone all funny and found hose had been modified also.
Click4
Postby knobby1 » Tue Feb 27, 2018 7:57 pm
Will take a while for all the old coolant/water to be burnt/blown out of the exhaust, muffler etc....as mentioned before...it's probably not smoke, it's more likely steam.
If it is indeed smoke, you've got issues other than the EGR cooler. Pop the boost hoses of the intercooler and see if there's a silly amount of oil in there. There will be some oil coating the inside of the hoses etc, this is normal.
Postby Click4 » Tue Feb 27, 2018 8:21 pm
Yep it will take a while but still stinks of diesel,
Suspect it’s down to this.
Injector 1 the ecu is dumping extra fuel... maybe it’s not atomising correctly.
Then it is reining the fuelling back on next cylinder to fire, number 3.
Going to check turbo next as well.
But fuelling isn’t right on it still.
Click4
Postby knobby1 » Tue Feb 27, 2018 9:58 pm
Click4 wrote:Yep it will take a while but still stinks of diesel,
If the injector "Pilot Learns" been done successfully, (as you mentioned), they should be OK. The learn process will fail if the injector pressures & flows are not within fairly tight limits.
Postby Click4 » Tue Feb 27, 2018 10:01 pm
True but that was done after I replaced the first 2 injectors.
It didn’t start smoking like this till about 2 weeks later.
Click4
Postby knobby1 » Tue Feb 27, 2018 10:32 pm
Click4 wrote:True but that was done after I replaced the first 2 injectors.
You may have to run the learns again, just to make sure the injectors are up to snuff. Might pay to do a "Leak-off" test too.
Did you say 2 of them were "reconditioned"..?? If so did you get new calibration reference codes with them..??
Postby Click4 » Wed Feb 28, 2018 12:02 am
When I got the van it had 2 original injectors in it and 2 recon
The recon ones had square bits stuck over original codes so they did have new codes.
When it first started smoking white smoke, was only a little bit, but did leakoff test, and 1 original and 1 recon injector wasn’t right, they both practically filled bottles up.
So I replaced both of them with brand new injectors and codes them. Did pump and pilot learn and was all good for around 2 weeks.
Then started smoking bad.
Already done a leakoff test again. The 2 new injectors both leakoff equal amounts, and the 1 original and 1 old recon also both leaking off pretty equal amounts but slightly more than the new ones which is expected as they are older.
But none standing out like before.
Only becomes apparent there is an issue with number 1 or 2 when you look at the correctional values. Ecu thinks cylinder 1 is under fuelling so it’s injecting more fuel. Which presumably is causing too large an increase in engine speed so it draws back cylinder 3 to even it out.
Click4
Postby knobby1 » Wed Feb 28, 2018 1:19 am
Click4 wrote:Only becomes apparent there is an issue with number 1 or 2 when you look at the correctional values. Ecu thinks cylinder 1 is under fuelling so it’s injecting more fuel. Which presumably is causing too large an increase in engine speed so it draws back cylinder 3 to even it out.
This doesn't sound right....the PCM isn't smart enough to make those adjustments/changes, it only injects the required amount/timing depending on the engine load, rpm and throttle position in relation to the individual correction factors entered into the system. I'd run the pump and injector pilot learns again, if they are successful, it "should" be running ok...
Have you have the codes read recently...??
