2009 (59) MK7 Transit 2.4 RWD 115 - White Smoke
Postby Click4 » Wed Jan 24, 2018 10:43 pm
Hi, just looking for ideas.
Few years back, 3 years, prior owner had engine rebuilt and 2 recon injectors.
White smoke, did leakoff test, injectors 2+3 leaking off too much diesel, injector 3 was the worst, almost filled bottle.
One of them, can’t remember which one now was one of the recon injectors.
Fitted 2x new Delphi injectors, to 3+4, Genuine ford Diesel Filter.
1+4 (one original and 1 recon) sent for testing which returned good, then refitted to 1+2
Reprogrammed all 4 injection correction codes to correct cylinders.
Noticed that cylinder 2 previously was a load of 000s prior to me reprogramming the correction codes.
Did injector pump learn which completed successfully.
Did injector pilot learn which completed successfully.
But still lots of white smoke intermittently and today started and it shut off.
Any ideas?
Can’t be injectors, 2 are brand new and 2 was tested as fine by a diesel specialist.
Click4
Re: 2009 (59) MK7 Transit 2.4 RWD 115 - White Smoke
Postby andz327 » Wed Jan 24, 2018 11:15 pm
What shut off, do you mean it cut out and won't start ??
andz327
Postby Click4 » Wed Jan 24, 2018 11:21 pm
Engine shut off, does restart just lots of White smoke.
I’m thinking possibly EGR, but also read about SCV and PRV problems also
Click4
Postby knobby1 » Thu Jan 25, 2018 12:38 am
Click4 wrote:Engine shut off, does restart just lots of White smoke.
Do you have an EML on the dash..?? Codes read..??
Postby andz327 » Thu Jan 25, 2018 12:53 am
Sounds like injector issue again , do another leakoff test and as his lordship mentioned check for codes
andz327
Postby andz327 » Thu Jan 25, 2018 12:59 am
andz327 wrote:Sounds like injector issue again , do another leakoff test and as his lordship mentioned check for codes
Check in case the injector clamp has loosened off , sometimes fitting them you can catch an edge with clamp and gives a false tightness and slackens off shortly after running
andz327
Postby Click4 » Thu Jan 25, 2018 2:47 am
No codes, no eml either
Could be but 2 injectors were brand new! Never used, weren’t even recon, fresh from denso and other 2 had tested and they said they checked out fine.
Will check injector clamps again.
Click4
Postby andz327 » Thu Jan 25, 2018 11:35 pm
Click4 wrote:No codes, no eml either
There's few places that can properly test these injectors mate was it a big reputable company like PF Jones
andz327
Postby Click4 » Fri Jan 26, 2018 10:17 pm
I’m going to assume the 2 brand new non recon ones should be ok.
Smoking seems to of stopped so will keep an when and see how it goes.
http://www.essexdiesel.co.uk/diesel-fuel-injection.html
That was where i had them tested, he reconditions them also.
Don’t know if he’s any good but he charged £30 to test 2 injectors.
Dropped them down in afternoon.
Following morning I picked them up, he had cleaned them and put caps on them and said they was all fine, I even asked about spray pattern and he replied again yep all good.
Click4
Postby Click4 » Fri Feb 16, 2018 11:06 pm
Still not right.
Started it up other day massive cloud of white smoke like during pilot learn process I did weeks back.
Revved it a bit and the smoke cleared and it has been fine again ever since until yesterday, started it, no white smoke but engine shuddered badly then just shut off on its own.
Restarted after and again perfectly fine.
:( any ideas?
Click4
Postby andz327 » Sat Feb 17, 2018 2:59 pm
Click4 wrote:Still not right.
:( any ideas?
Must have codes now , have you done another leak off test
andz327
Postby Click4 » Mon Feb 19, 2018 12:57 pm
Absolutely no codes at all.
Checked several times, not even a check engine light.
When it’s running it’s fine it’s when you start it occasionally clouds of white smoke that disappate and also sometimes a shudder with engine shutting off.
Click4
Postby Click4 » Mon Feb 19, 2018 12:59 pm
To me clouds of white smoke on startup sounds like a dripping injector leaking diesel into cylinder.
But I had the 2 tested which supposedly came back fine
Click4
Postby Click4 » Mon Feb 19, 2018 7:53 pm
Become a little more permanent now....
Yet runs fine, no misfire no uneven running revs fine etc no error codes etc
Click4
Postby andz327 » Mon Feb 19, 2018 11:10 pm
Seems injector problem,Were the injectors torqued down properly with new washers and bolts
andz327
