k11gmh wrote:Thanks to all for the info and advice going to remove the vac pump and look at the oil ways as described and hope to see signs of oil if nothing back to the garage. I must say with all the work done the garage that replaced the turbo and fuel pump plus the contaminated fuel tank they never changed the oil or oil filter would of thought that would of been a matter of course your thoughts ??
k11gmh wrote:Thanks one and all now had an engine flush and new oil filter plus oil of course, sounds like a different engine plus the vac pump yes runs hot but not as hot as before sad that the cost of £80.00 for the oil change could have saved me £420.00 to change the water pump and vac pump.
