Air con Diagram/Info.
Re: Air con Diagram/Info.
Postby andz327 » Wed Feb 07, 2018 5:48 pm
Tracey74 wrote:Well, I have made my view very clear, I will not except another bodge job!
I shall be looking at what They alphabet put back?!!!
And have told them, as soon as I get van back it’s going straight to a AC Specialist, which it is for a second opinion!
Their excuse was, We had to take all that away to WElD!
I said you have BUTCHERED MY VAN without even asking!!! :oops:
If they're not replacing the pipes They'll probably try to join using brass plumbing fittings like a 10mm strait coupling like the one in picture which i used to sort my power steering pipe until the new one came
andz327
Postby Tracey74 » Wed Feb 07, 2018 8:51 pm
No News from garage today.
I think they having problems.
Tracey74
Postby Altransit » Wed Feb 07, 2018 8:59 pm
Putting right that butchery, is not going to be a fast job :(
Postby paul2012 » Thu Feb 08, 2018 7:39 pm
Tracey74 wrote:
So I have found 2 pipes at the top sawn off and blacked over and 1 pipe at the bottom sawn off, Accumulator/dryer is totally missing.
Been back to the garage.
Had a Huge argument with the Owner, and I made him bring out the mechanic who BUTCHERED MY AIR CON.
After 30mins of B***s***......
He agreed they are at fault.
They now have the van and Amazingly have found my Pipes and the Accumulator!
I have been promised they will put it all back together????
But how?
They are telling me that they can re join the pipes???
I am not confident...
But will give them a chance.
I've just seen seen this thread.
Those 2 pipes. 1 goes to accumulator & the other 1 goes to condenser.
Obvious that welding has been dove in that area (O/S wheel house panel & inner wing). BUT there was no need to cut A/C hoses.
All they had to do was depressurise A/C system & thee remove pipes & accumulator. Complete repair, then refit A/C pipe & recharge the system. :roll:
Me. I would be double checking the welding they've done too :idea:
Who did the work :?: :?:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby andz327 » Fri Feb 09, 2018 12:19 am
But how?
Can imagine what their welding must be like if that butchery is anything go by
andz327
