I have a motorhome based on a 2004 125 T350. I lifted the bonnet yesterday to disconnect the Winter battery charger, and saw that it had slipped back and sheared off the small glass-like primer pump ( Is it called a primer or a sensor?) on top of the fuel filter. I've hopefully attached pics of the part. Anyway, I did a temporary fix with a good collar of epoxy, and re-fitted the part. Engine wouldn't start, so I inserted a small rod through the hole in the rubber cap, and pumped it up and down for a minute. Still no start. So here are my questions:
1) What's it called?
2) Can I buy one, new or s/h, in the UK? (I'm in rural West Cork,Ireland,the Ford dealer is miles away, and I rang they said I'd have to buy the whole filter unit!!!)
3) Should I have primed for longer, is there a bleed screw, and if so, where is it?
4) One local mechanic suggested I fit a blanking bolt in place of the part, as a short or even long-term fix. Stupid idea or not?
5) Finally, assuming that my problem is similar to running out of fuel and re-filling, surely the primer should be sufficient to enable a re-start?
Thanks in advance for advice/suggestions/offers of replacement part!
