dipped lights not working
Postby john48 » Thu Feb 08, 2018 9:19 pm
hello i have a 2007 2.2 fwd swb 110 transit. my dipped lights stopped working possibly coincidentaly after i reconected the battery. ive swapped around the relays fitted new bulbs checked as many fuses as i thought it would be (cant find a fuse diagram that looks similar to my one) and swapped out the light control switch for a second hand one i got off e-bay ( i suppose theres a small possibility this one could also be faulty if that is the problem). Is there anything else that i can check that i dont know about. thanks.
john48
Re: dipped lights not working
Postby Altransit » Thu Feb 08, 2018 10:10 pm
Possibly, the dip/main beam switch :idea:
Postby john48 » Sun Feb 11, 2018 8:58 pm
thanks for the reply where is the switch?
john48
Postby john48 » Sun Feb 25, 2018 3:28 pm
dropped the van into my mechanic he recons the fuse box got corroded from dampness or something spilled on it and had to wire the lights off the relay for the sidelights.
john48
Postby andz327 » Sun Feb 25, 2018 10:39 pm
john48 wrote:thanks for the reply where is the switch?
Ehhh
andz327
