Mk 7 help required
Mk 7 help required
Postby bob mann » Wed Feb 14, 2018 11:27 pm
Hi all I have a 2008 2.2 tdci, went out today all was well noticed after a while when easing off the accelerator van started to judder like it was not getting fuel but ok while accelerating, gradually got worse so pulled into supermarket car park .
seemed to idle ok turned off then will not start at all ???
called AA he sprayed some startup in the engine and it stated but run really rough and smoked like a bitch!!!
He said he thought it was an injector fault
I have since read that it could be fuel inlet valve and pressure relief valve problem
So I am confused now can any garage sort this as I'm told it needs either coding for injectors or software updates doig also or do I need to go to ford dealer
Any help or advice would be most welcome as this is my first transit van
bob mann
Re: Mk 7 help required
Postby Punto443 » Wed Feb 14, 2018 11:31 pm
Injectors do need coding, but most diagnostics can do this if the operator is capable. Doesn’t need to be ford.
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby bob mann » Thu Feb 15, 2018 12:46 am
Thanks for that :D
bob mann
Postby knobby1 » Thu Feb 22, 2018 2:42 am
Strange that it happened all of a sudden though...possibly the PRV has blown..??
Best get the codes read to see what is going on.
