ABS wires ??
ABS wires ??
Postby Pete.s » Sat Feb 17, 2018 10:01 pm
2005 t280 swb, found these wires broke / cut today, look like ABS wires going into the back plates of my rear brake drums, the wires are cut just above the flexi hose to metal brake pipe connectors on the beam axle, question is why do i not have any warning lights on the dash?, and will my abs brakes still work?
Pete......
If its got T*ts or Tyres yr in for Trouble :lol:
Pete.s
Re: ABS wires ??
Postby andz327 » Sat Feb 17, 2018 10:12 pm
[quote="Pete.s"]2005 t280 swb, found these wires broke / cut today, look like ABS wires going into the back plates of my rear brake drums, the wires are cut just above the flexi hose to metal brake pipe connectors on the beam axle, question is why do i not have any warning lights on the dash?, and will my abs brakes still work?
Pete......
Is your abs working ?
andz327
Re: ABS wires ??
Postby Punto443 » Sat Feb 17, 2018 10:30 pm
Do you have abs?
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: ABS wires ??
Postby Pete.s » Sat Feb 17, 2018 10:45 pm
andz327 wrote:
Pete.s wrote:2005 t280 swb, found these wires broke / cut today, look like ABS wires going into the back plates of my rear brake drums, the wires are cut just above the flexi hose to metal brake pipe connectors on the beam axle, question is why do i not have any warning lights on the dash?, and will my abs brakes still work?
Pete......
Not sure?, brakes appear to work ok, only had the van 2 weeks,
Pete.s
Re: ABS wires ??
Postby Pete.s » Sat Feb 17, 2018 10:47 pm
Punto443 wrote:Do you have abs?
I'm guessing I have, if I dont why is ther ABS wires?, well I'm assuming they are ABS wires, will look under the bonnet tomorrow
Pete.s
Re: ABS wires ??
Postby andz327 » Sat Feb 17, 2018 10:55 pm
Pete......
Was wondering that maself mate was it not standard on them in 2005, a know ma 55 plate had but it was a higher spec job
andz327
Re: ABS wires ??
Postby ned » Sat Feb 17, 2018 10:59 pm
andz327 wrote:
Pete......
I have abs :) doesn't bloody work :( I need to change the front n/s sensor, as for warning lights well there are ways to turn them out :wink: N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Re: ABS wires ??
Postby andz327 » Sat Feb 17, 2018 11:03 pm
ned wrote:
andz327 wrote:
Pete......
[quote="Punto443 wrote:Do you have abs?
I have abs :) doesn't bloody work :( I need to change the front n/s sensor, as for warning lights well there are ways to turn them out :wink: N[/quote]Now no bad habits please mr Ned
andz327
Re: ABS wires ??
Postby andz327 » Sat Feb 17, 2018 11:08 pm
andz327 wrote:
ned wrote:
andz327 wrote:
andz327"][quote="Pete.s"]2005 t280 swb, found these wires broke / cut today, look like ABS wires going into the back plates of my rear brake drums, the wires are cut just above the flexi hose to metal brake pipe connectors on the beam axle, question is why do i not have any warning lights on the dash?, and will my abs brakes still work?
Pete......
I have abs :) doesn't bloody work :( I need to change the front n/s sensor, as for warning lights well there are ways to turn them out :wink: N[/quote]Now no bad habits please mr Ned[/quote]Mr Ned sort mineImage
andz327
Re: ABS wires ??
Postby Pete.s » Sat Feb 17, 2018 11:10 pm
the wires look like they were cut on purpose, but why do that?, an surely it would be an MOT fail with cut abs wires would it not
Pete.s
Re: ABS wires ??
Postby ned » Sat Feb 17, 2018 11:14 pm
Pull the fuse :lol: if that don't work unsolder the led :wink: N
ned
Re: ABS wires ??
Postby ned » Sat Feb 17, 2018 11:17 pm
Pete.s wrote:the wires look like they were cut on purpose, but why do that?, an surely it would be an MOT fail with cut abs wires would it not
People are lazy, instead of fixing the fault they cut the wires :roll: I thank as for mot if there's no warning lights its not a fail as long as the brakes meet the braking requirements. N
ned
Re: ABS wires ??
Postby Pete.s » Sat Feb 17, 2018 11:21 pm
Ah right that would make sense with some people, i thought MOT man would fail the cut wires though
Pete.s
