64 2.2 fuel cut off switch??
Postby MD motors » Mon Feb 19, 2018 7:44 pm
Hiya i have a customer with a 64 plate 2.2 transit that wont start
Initial diagnostics showed low rail pressure on cranking
Checked for fuel delivered at high pressure pump and had none.
If you jump the fp relay it starts but there is no switched earth from body control module/engine ecu
Is there a fuel pump cut off switch anywhere??
Please help
MD motors
Re: 64 2.2 fuel cut off switch??
Postby loot » Mon Feb 19, 2018 8:56 pm
Some have a yellow square rubber reset button which is located behind the glovebox looking up and left to the A post area.
The transit custom has a pcm shutoff which when tripped requires a series of key cycles to reset.
It should be in the handbook which you have.
Only applies to vehicles with electronic fuel pump.
You can rely on the above about 99% but either way won't take long to check :-)
Ids map here
loot
Postby MD motors » Mon Feb 19, 2018 9:01 pm
Thanks for the reply, pretty sure this is a transit custom. Do you have any idea what the Ignition procedure is? And would this stop the switched earth?
Thanks again
MD motors
Postby loot » Mon Feb 19, 2018 10:06 pm
When I bought my van it was smashed and I recall the display telling me what to do which I basically turned the ignition on and off a few times, only done it once though so it's a bit vague, also I have the high spec speedo with colour display and sat nav colour display in the centre.
I would expect that if your van has no warning lights or info on the display or any other lights flashing then surely it isn't in limited mode?
Have you had it on diagnostics like ids for specific code read?
Ids map here
loot
Postby MD motors » Mon Feb 19, 2018 10:18 pm
Yes i have done diagnostics,cant recall exact code however the text is low pressure on cranking. If i clear the code then bridge the relay it will start with no codes because the fuel pump is working.
I would also like to think if the van was stopping its self starting via a programmed inertia switch built into pcm there would either be a fault code or message on dash but with modern cars it wouldnt suprise me if you had no warning at all. As in this day and age we are all supposed to be diagnostics gurus to keep these things on the road
MD motors
Postby loot » Mon Feb 19, 2018 11:28 pm
That's true, I would expect a code if it was tripped though, if it hasn't been crashed though is it likely that it is even tripped?
If you can confirm that it is a custom.
Pm me your email m8
Ids map here
loot
Postby MD motors » Tue Feb 20, 2018 10:05 am
yes bud its definitely a custom you have pm
MD motors
Postby loot » Tue Feb 20, 2018 10:58 am
Replied
Ids map here
loot
Postby Domgun » Wed Sep 18, 2019 4:02 am
Hi did you resolve this issue as I have the same problem thanks
Domgun
Return to Transit Custom
