bigjohnthomas wrote:Take the caliper off and move it in and out and put some love juce on it
Bloody annoying squeeeeek that
Worst thing I’ve ever heard. Goes right through you
Birmingham wrote:just a bit of lube ?Punto443 wrote:Mine was doing this and it was the handbrake lever on the rear caliper sticking
Punto443 wrote:Birmingham wrote:just a bit of lube ?Punto443 wrote:Mine was doing this and it was the handbrake lever on the rear caliper sticking
I freed it off a couple off times, but long term it needs striped down and seals changed. £8 for seals and an hours work
TallPaul wrote:I had some pattern rear pads in my Custom and the friction material started delaminating from them, I'd get an irritating squeal once they'd warmed up. Does it go when the brakes/handbrake are applied? Take the pads out and check them.
Did a pad change cure the problem ? Thanks for replyingTallPaul wrote:I had some pattern rear pads in my Custom and the friction material started delaminating from them, I'd get an irritating squeal once they'd warmed up. Does it go when the brakes/handbrake are applied? Take the pads out and check them.
