Good day one and all.
I have bought a ELM327 and used the Forscan to find out what is going on with the van. Cleared all the exsisting codes, many, and went for a drive, urban and motorway, then rechecked the codes. I have 1 P0171, system too lean bank one. One of the list possible faults is HO2S11 circuit, so I went out again and did a oscillascope record of both oxygen sensors. O2S11_V,volt and O2S12,volt. Very differant readings, O2S11 started off at 0.9 and, when starting the engine and then bounces between 0.04 and 0.75(ish) and O2S12 starts of at 0.0 and gradually increases to 0.9, almost following the water temp. I also had INJ_F, No fault throughout the trips. I cannot find a parameter that records the fuel pressure so I have to figure out how to check it, a book is arriving soon.
A question for you. What is the O2S graph supposed to look like please.
I can post the file if needed.
Thanks for any advice.
