Hi Folks , looking for assistance .
I have an 02 year - 2.0 litre transit van. Just your bog standard one. Sorry thats as much info as I know.
The engine is over heating , cutting out . The water pipes etc that run from radiator to water tank / housing where you top up with anti freeze /water isnit heating up , pipes not getting warm ( there isint a blockage as when you squeeze the pipes it is making ripples in the tank . The air / vents inside van is also blowing cold air . It has just had a new thermostat fitted .
Any ideas ? Thanks
