V8_Bodge wrote:Can a Mk6 2.4 engine be fitted to the Mk7 five speed gearbox?
V8_Bodge wrote:I am fitting a Mk6 2.4 engine and gearbox with all the parts inc the dash and propshaft to get it running to a Mk7 van and thought it may be easier to fit it to the original cable type gearbox.
Punto443 wrote:Canny mind the guys name? Matt? , but the dudes got a cherry picker profile pic, 99% sure he done it.
knobby1 wrote:V8_Bodge wrote:I am fitting a Mk6 2.4 engine and gearbox with all the parts inc the dash and propshaft to get it running to a Mk7 van and thought it may be easier to fit it to the original cable type gearbox.
If that's the case, then you'll need all the Mk6 engine bay, ECU/PCM wiring looms, and dash looms as well...the Mk6 & Mk7 wiring system is totally different in that respect. The Mk6 is obviously TDDi and the Mk7 TDCi...so all the engine running looms and control modules are completely different...Then there's the matter of the different braking systems etc...it's gunna be a rather big and challenging modification.
V8_Bodge wrote:I have everything from the Mk6 you mention, what is the difference in the braking systems? ABS and body control?
V8_Bodge wrote:I know the Mk6 engine doesn't bolt onto the Mk7 six speed, was hoping that someone would know if the five speed bolted direct.
knobby1 wrote:V8_Bodge wrote:I have everything from the Mk6 you mention, what is the difference in the braking systems? ABS and body control?
Shouldn't need to worry about the brakes if you're fitting the Mk6 engine into a Mk7 van....although I'm not sure if the original Mk7 PCM talks to the BCM and ABS modules. The Mk6 has drums on the rear and the Mk7 has discs all round, so one would imagine the braking system & ABS system is different to the Mk6.
