Fuel rail pressure for 2007 115 rwd
Postby Craigemm123 » Wed Mar 07, 2018 4:37 pm
Hi all
I've just joined the site so this is my first post / question.
I have a 115 t350 2007 rwd and have a starting issue, does anyone know the correct PSI I should be getting for the fuel delivered to the rail as mine is fluctuating by nearly 1000 on tick over?
Craigemm123
Re: Fuel rail pressure for 2007 115 rwd
Postby knobby1 » Wed Mar 07, 2018 9:29 pm
Craigemm123 wrote:Hi all
What are you reading the pressure with??
Idle rail pressures are usually up in the ~30,000kpa, (~4350psi) region. This will climb dramatically as engine rpm and load increases and can be upwards of 200,000kpa (~29,000psi)..
If you're pressures are fluctuating dramatically, I'd suspect you SCV may be playing up.
Postby Frag » Wed Mar 07, 2018 11:11 pm
Should be 230 bar at idle...
With no faults it won't vary very much at all,
+/- 30 bar max,about acceptable.
Frag
Ford Technician
Postby daraioj » Wed Mar 07, 2018 11:31 pm
Frag wrote:Should be 230 bar at idle...
Hey all, my 100ps mk7 idles at 500bar and doesn't vary much when accelerating. It passed a pump learn and pilot learn first go. No error codes and works fine.
I know this may sound like a very stupid question but I also know that fuel pressure issues can end up being very expensive if not looked after, so is it something I should be worried about? Anything I should check?
Thanks in advance
2010 2.4L RWD 100ps MT75 LWB High Roof
daraioj
Postby Frag » Wed Mar 07, 2018 11:36 pm
What are you using to measure that pressure with ?
That's nowhere near right,but if that's the case,also it wouldn't pass pump or injector learns....
Frag
Ford Technician
Postby daraioj » Wed Mar 07, 2018 11:41 pm
Frag wrote:What are you using to measure that pressure with ?
I'm using Forscan. It shows 48000 to 50000 kpa
daraioj
Postby daraioj » Thu Mar 08, 2018 12:08 am
I'll give the learns another go, I did them a couple of months ago. In any case shouldn't I be getting some full pressure related codes?
daraioj
Postby Craigemm123 » Thu Mar 08, 2018 10:11 am
I’m using a laser 5091 which I’ve had for years but does the basics, I suspected the SCV but local garages keep saying injectors ! I’ve already paid for 2 to be changed but that obviously isn’t the issue and as one of you said the re learns failed when they changed these so I’m fixing myself now.
Craigemm123
Postby daraioj » Thu Mar 08, 2018 5:43 pm
Is there anything else that could be causing pressure issues (other than the SCV)?
Seems like mine can't match the desired pressure when it drops below 500 bar.
Is that enough to say the SCV needs replacing or is there anything else I can test?
daraioj
Postby v8dave » Sat Mar 10, 2018 3:54 pm
Looks like the scv not functioning correctly.
The scv mechanically defaults to open.
The pcm closes it to limit fuel pressure.
As you fuel pressure is high at idle it looks like the scv is not closing, this could be a mechanically jammed scv or an electrical issue.
v8dave
Postby daraioj » Sat Mar 10, 2018 10:05 pm
v8dave wrote:Looks like the scv not functioning correctly.
Thanks for that info!
Today I used torque and another ELM adapter to log a 30ish km drive. Pressure fluctuated between 500 bar at idle and 1600 at full load.
Then I did a pump learn expecting it to fail. Just to confirm my SCV was gone but... It completed successfully first go. (Did a pilot learn while I was at it)
Now it's idling at 230. I'll log another run and see how high it goes.
I don't get it though, the last pump learn was done 5000km ago. Am I missing something?
Also, if the comments above are correct and PRV's blow at 1600bar then I'm in trouble. What would be the symptoms?
daraioj
Postby grogan197 » Sun Mar 11, 2018 3:14 pm
Normal operating pressure is up to 1600 bar so the PRV won't go until over that, not sure what the limit is though. If the PRV blows then you'll have a check engine light on the dash.
2006 MK6 2.0 125 TDCI - Luton Camper Conversion
2007 MK7 2.2 110 TDCI SWB
Ford Diagnostics
Where to buy an ELM327 and how to use with ForScan
grogan197
Postby daraioj » Sun Mar 11, 2018 3:16 pm
grogan197 wrote:Normal operating pressure is up to 1600 bar so the PRV won't go until over that, not sure what the limit is though. If the PRV blows then you'll have a check engine light on the dash.
Perfect! Thanks a lot for that info
daraioj
