v8dave wrote:Looks like the scv not functioning correctly.
The scv mechanically defaults to open.
The pcm closes it to limit fuel pressure.
As you fuel pressure is high at idle it looks like the scv is not closing, this could be a mechanically jammed scv or an electrical issue.
Thanks for that info!
Today I used torque and another ELM adapter to log a 30ish km drive. Pressure fluctuated between 500 bar at idle and 1600 at full load.
Then I did a pump learn expecting it to fail. Just to confirm my SCV was gone but... It completed successfully first go. (Did a pilot learn while I was at it)
Now it's idling at 230. I'll log another run and see how high it goes.
I don't get it though, the last pump learn was done 5000km ago. Am I missing something?
Also, if the comments above are correct and PRV's blow at 1600bar then I'm in trouble. What would be the symptoms?
