Transit Trend 2lit interior cab light fuse
Postby 24rcouk » Fri Mar 09, 2018 3:58 pm
We just bought a new 2018 ford transit trend panther 2 lit diesel in which we have blown the interior light fuse, but unfortunately the fuse location for the interior light is not listed in the owners manual and ford tech help line couldn't help either, apart from helping themselves to £6 of my money for a premium rate call. I also called into the local dealers who advised me that it would have to be booked in so their technician could try to find it.
Has anyone else had this problem that could help me.
PS it's the permanent light fuse not the fuse for the light which comes on when the door is opened as this part of the light still works ok.
Hugh
24rcouk
Re: Transit Trend 2lit interior cab light fuse
Postby loot » Fri Mar 09, 2018 4:55 pm
Is this a transit or a transit custom?
Ids map here
loot
Postby 24rcouk » Fri Mar 09, 2018 5:04 pm
It's officially called a ford Transit Panther Trend not the custom or connect version
24rcouk
Postby loot » Fri Mar 09, 2018 5:53 pm
Ok have you got a picture? :-)
Ids map here
loot
Postby Frag » Fri Mar 09, 2018 8:58 pm
That's got to be a mk8,panther engine and trend trim spec.
There are 2 fuse boxes,1 behind each trim panel infront of either leg drivers side.
I don't have a handbook here but would have thought fuse info was in there ?
Frag
Ford Technician
Postby 24rcouk » Tue Mar 13, 2018 9:48 am
We checked both fuse boxes with no success we have now left the van to a ford main dealer I'll let you know the result.
Hugh
24rcouk
