key fob /cenral locking
Postby Timothy lowe » Tue Mar 13, 2018 9:24 pm
Hi there I'm a newby on here !just bought new mk 7 transit 2010 plate ,iv added a couple usb /12v supply in back off van and conected it straight to my battery at the back off seat via a inline fuse and switch , got everythinking working ok.came to lock van with remote and did not work and was fine till i made coections to battery .This batterty is not even 2 year old but the front battery has a date on it from manafacture from 2010 so checked what voltage it was giving out and was over 12v not started and increased when van running ! checked fuse behind glove box and was ok ,Is there any more anywhere or could i off damaged something else when connecting my new usbs !! its doing head in hope some one can help !! PLEASE THANKS
Timothy lowe
Re: key fob /cenral locking
Postby loot » Tue Mar 13, 2018 11:24 pm
You need to get the front battery drop tested but if it is 8 years old then 99% likely it is fooked, get a new 1 the same spec as the back 1 that you have that's assuming it is the correct spec for the van :-)
Ids map here
loot
Postby Timothy lowe » Wed Mar 14, 2018 11:54 pm
Well with it bieng 8 year old I will just change it anyway and hope the sorts it out ! Cheers
Timothy lowe
Postby Timothy lowe » Thu Mar 15, 2018 10:19 pm
Timothy lowe wrote:Well with it bieng 8 year old I will just change it anyway and hope the sorts it out ! Cheers
Changed the battery and worked first time .ffs
Sent from my SM-A300FU using Tapatalk
Timothy lowe
Postby loot » Thu Mar 15, 2018 10:59 pm
8)
Ids map here
loot
Postby knobby1 » Fri Mar 16, 2018 3:14 am
Result..! :D
