ABS Light No Speedo and Stabilty Airbag lights
Postby waitey1 » Thu Mar 15, 2018 8:06 pm
Hi All
Has anyone suffered same faults and lights as above!?
I had a play last night with abs sensor connections and cleaned them
With all snow etc. Lights went out for 20 miles but Now back on again
Is there anyone on here that has FORD IDS software near Rochdale other than fords.
Many thanks
waitey1
Re: ABS Light No Speedo and Stabilty Airbag lights
Postby grogan197 » Fri Mar 16, 2018 12:04 am
Get the free software ForScan and a cheap ELM327 and you can check yourself. You'll be able to view any error codes from the ABS system and with live data you can see the wheel speed for each of the wheels from the ABS sensors.
2006 MK6 2.0 125 TDCI - Luton Camper Conversion
2007 MK7 2.2 110 TDCI SWB
Ford Diagnostics
Where to buy an ELM327 and how to use with ForScan
grogan197
