MK7 Recurring Heater Problems :(
Postby zcharythomas » Fri Mar 16, 2018 2:40 pm
Got myself 2011 Ford Transit T330, 2198CC (ex-AA) with 192,000 on the clock. When I picked it up heaters were working absolutely fine for a few days and then it only started blowing cold air. Took it to the Garage he said was probably the pipe, so he squeezed it and an hour later was working again- took it back anyway and got a new one fitted. Worked fine for about a month and a half and it's gone again... Cold air on any setting.
Anyone have any suggestions? It's driving me mad as I use it for work.
Cheers
zcharythomas
Re: MK7 Recurring Heater Problems :(
Postby knobby1 » Sun Mar 18, 2018 8:29 pm
zcharythomas wrote:Got myself 2011 Ford Transit T330, 2198CC (ex-AA) with 192,000 on the clock. When I picked it up heaters were working absolutely fine for a few days and then it only started blowing cold air. Took it to the Garage he said was probably the pipe, so he squeezed it and an hour later was working again- took it back anyway and got a new one fitted. Worked fine for about a month and a half and it's gone again... Cold air on any setting.
Anyone have any suggestions? It's driving me mad as I use it for work. Cheers
Heater tap sticking closed maybe or it's vacuum actuator dead or dying..??
Postby bambi mk 1 » Sun Mar 18, 2018 8:39 pm
He will have some job finding a tap Knobby ,its a flap in the heater box that redirects the air :wink:
Op have you checked the water level and what pipe did they squeeze and replace :?:
bambi mk 1
Postby knobby1 » Sun Mar 18, 2018 9:03 pm
bambi mk 1 wrote:He will have some job finding a tap Knobby ,its a flap in the heater box that redirects the air :wink:
Mine has a heater tap, on the matrix/heater hoses just before they go through the firewall from the engine bay..! Here:
But it's probably the heater box flap as you say....I think BJT had a fix for this..! :mrgreen:
Postby v8dave » Mon Mar 19, 2018 9:55 pm
Knobby, they are I believe only fitted on vans with aircon.
Shame really as being able to stop hot water coming through the bulkhead in the summer would benefit all vans.
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Postby Punto443 » Mon Mar 19, 2018 10:02 pm
Does the van have air con?
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby knobby1 » Tue Mar 20, 2018 2:36 am
Punto443 wrote:Does the van have air con?
Aye...Mine does..! :wink: :wink:
Postby zcharythomas » Sat Mar 31, 2018 1:20 pm
Update:
Took it to the garage after further few weeks of cold air. He rang me and said it's fine and blowing hot?! Literally so confused. Anyway I got it back, was blowing hot, too hot, so I turned it to midway- totally cold again now. I'm not a mechanic so what would you guys suggest? Indie garage can't seem to work it out so should I just take it to Ford?
Water levels fine and yeah it has aircon
PS Thanks for your help.
zcharythomas
Postby Punto443 » Sat Mar 31, 2018 1:39 pm
On air con models there is a electrical actuator that controls the hot/cold mix, it’s probably in its way out :?
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby Chiz69 » Sat Apr 14, 2018 10:14 am
Is the air con thingy behind the air con button ? Is ir easy to change ?
Chiz69
Postby Chiz69 » Sat Apr 14, 2018 10:15 am
Previous owner says its the heater valve ( vacuum model )
Chiz69
