Connect 1.5d timing belt marks 2015my
Postby AFCMad » Fri Mar 16, 2018 8:40 pm
Evening all.
Have been looking at a connect which refuses to start.
(Was starting and running fine up until the cold spell the other week.)
Was advised it was a starter motor issue but is cranking lovely.
Oil level was VERY low so topped it up.
Coolant bottle showing signs of oil contamination but not the worst I've seen.
Seems to have no compression and will not even attempt to start on easystart.
And no trouble codes in the ecu
Suspecting a jumped belt
Started to strip down timing belt cover and realised cannot find any timing marks or info on interweb!
Could someone pls point me in the right direction for timing it up?
(If it has jumped then its going somewhere else for repair!)
As usual, thanks in advance for all and any help!!!
AFCMad
Re: Connect 1.5d timing belt marks 2015my
Postby karl » Fri Mar 16, 2018 10:48 pm
does it have the wet belt system
what year is the van :D
karl
Tranny Lover!!!
Postby bambi mk 1 » Fri Mar 16, 2018 11:20 pm
Bet you £100 its 2015 Karl :lol:
bambi mk 1
Postby karl » Fri Mar 16, 2018 11:23 pm
well hello mr perfect :roll: :lol:
karl
Tranny Lover!!!
Postby karl » Fri Mar 16, 2018 11:26 pm
AFCMad wrote:Evening all.
hello there you need to strip the engine down
these have a wet belt from crank to pump. and i suspect the wet belt has snapped or stripeed teeth from no oil changes
karl
Tranny Lover!!!
Postby bambi mk 1 » Sat Mar 17, 2018 12:18 am
Bet another £100 it dosent have a wet belt :lol:
bambi mk 1
Postby AFCMad » Sat Mar 17, 2018 12:57 am
Thanks for the replies!
It IS a 2015 model
Can't confirm its a wet belt but doesnt look like it......
Won't be playing with it again until Monday so can't say who iwes who how much yet.........
(How are you so confudent it's a 2015?)
AFCMad
Postby karl » Sat Mar 17, 2018 1:14 am
AFCMad wrote:Thanks for the replies!
It IS a 2015 model
FORD have a thing were they fit old bits to new vans
but yours being a 2015 i might have to listen to bambi :lol: :lol: :lol: :lol: :shock:
karl
Tranny Lover!!!
Postby AFCMad » Sat Mar 17, 2018 1:30 am
Ok.
I will strip it and report back......
Thanks again....
AFCMad
Postby paul2012 » Sat Mar 17, 2018 2:41 am
Ford PSA 1.5 TDCI engine.
There are no timing marks. Engine locking kit is used. Locks off crank, cam & FP - (Same as Citroen HDI)
I know there was a recall for these 1.5 engines fitted to Focus. Recall was for cam pulley replacement.
Don't know if it effected 2013> Connects too.
As it's a 2015 model. Would've though still under manfacturer's warranty :?:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby Altransit » Sun Mar 18, 2018 1:54 pm
paul2012 wrote:Ford PSA 1.5 TDCI engine.
It could possibly be the PSA 1.6? My sons 2015 Connect had that engine fitted, but they may well be similar in design :)
Postby bambi mk 1 » Sun Mar 18, 2018 2:17 pm
Its basically a 1.6 with a slightly smaller bore Al :)
bambi mk 1
Postby Altransit » Sun Mar 18, 2018 2:36 pm
bambi mk 1 wrote:Its basically a 1.6 with a slightly smaller bore Al :)
I had assumed so, but now I know definitely :mrgreen: :lol:
I have two Foci with the same engine :P
Postby AFCMad » Sun Mar 18, 2018 3:10 pm
Quick update, cos I know youre all worried and concerned, owner of said Transit Connect is having it taken to nearest ford agent for investigation and poss repair under warranty due to age and mileage......
Will keep you updated just in case anyone else suffers the same fault!
Thanks again for all the help...
AFCMad
Postby Altransit » Sun Mar 18, 2018 3:31 pm
Thanks :D
Keep us posted, if he keeps you posted please :mrgreen:
