blue estate wrote:2 As starting done by back one and all other circuits run by front but the front one gets low and because they're connected in parallel when ignition is turned on both are connected together but the front pulls the starter one down
Get 2 type 110 batteries as the factory fit are crap
Altransit wrote:blue estate wrote:2 As starting done by back one and all other circuits run by front but the front one gets low and because they're connected in parallel when ignition is turned on both are connected together but the front pulls the starter one down
Is it a Mk7 then
