Mk7 transit 2.4 oil leak
Postby Gertransit » Mon Mar 19, 2018 10:04 pm
Hi all had a few a oil leaks on my 2.4 transit when u drive it the entire engine bay was destroyed.the gaskets at the vacumn pump failed replaced them all good.it seems to weeping now out of the round plastic over in front of the fuel pump on the timing cover gonna order 1 in ford 2moro .anybody on here have this issue before thanks in advance
Gertransit
Re: Mk7 transit 2.4 oil leak
Postby knobby1 » Tue Mar 20, 2018 2:42 am
Gertransit wrote:Hi all had a few a oil leaks on my 2.4 transit when u drive it the entire engine bay was destroyed.the gaskets at the vacumn pump failed replaced them all good.it seems to weeping now out of the round plastic over in front of the fuel pump on the timing cover gonna order 1 in ford 2moro .anybody on here have this issue before thanks in advance
What model..?? Mk6...Mk7..?? PS..??
Postby Gertransit » Wed Mar 21, 2018 6:20 pm
Hi mk7 115 ps
Gertransit
Postby knobby1 » Wed Mar 21, 2018 9:29 pm
Gertransit wrote:Hi mk7 115 ps
Of course...you did say Mk7 in the title...I'm going blind in my old age :oops: ..!
I think they're all the same part number anyway..
Mk7:
http://www.catcar.info/ford/?lang=en&l= ... NisxMzM%3D
Mk6:
http://www.catcar.info/ford/?lang=en&l= ... NCsyNzI%3D
Postby Gertransit » Wed Mar 21, 2018 11:49 pm
Hi got a new part from ford and fitted it today problem still occurring with the engine on idle it's perfect soon as u drive it leaks outat the front cover on dsl pump
Gertransit
Postby knobby1 » Thu Mar 22, 2018 12:57 am
Gertransit wrote:Hi got a new part from ford and fitted it today problem still occurring with the engine on idle it's perfect soon as u drive it leaks outat the front cover on dsl pump
Could it be the timing cover itself rusty/porous?? Ford manual doesn't list any sealant for that area.
Postby v8dave » Thu Mar 22, 2018 9:48 pm
The round cover has a seal strip on it's rear face and this ages, becoming hard and ineffective.
You either buy a new cover or remove it ( it is a bayonet fitting, sixth of a turn to remove ) and degrease then apply sealer like loctite 5699.
v8dave
Postby knobby1 » Thu Mar 22, 2018 10:17 pm
v8dave wrote:The round cover has a seal strip on it's rear face and this ages, becoming hard and ineffective.
There ya go...I knew someone would know for sure...I've not had mine off yet..!
