loud knocking
Re: loud knocking
Postby v8dave » Fri Apr 13, 2018 7:58 pm
transitnewbie26 wrote:is there a cleaner for none hydraulic lifters?
Snake oil lifter treatments are not your answer, do not waste your money.
transitnewbie26 wrote:the guy said it could be the knocking is from the oil still not lubricating the parts fully and should wait a week to see if the knocking/ticking stops or it could be cam bearings.
There are no separate cam bearings on these engines. If the cam housings are gone you need a new cylinder head.
You might have a failed cam follower if there has been a lose of lubrication to the top of the engine, I'd have expected a reputable specialist mechanic to have know this and checked.
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Re: loud knocking
Postby andz327 » Fri Apr 13, 2018 9:49 pm
Dont waste your money on additives, it won't work , your mechanic guy obviously doesn't work on transits, the garage that repaired it should have stripped whole engine down if things got that bad that the oil pump seized or just replaced engine with a full running 2nd hand engine,
THERE AINT NO WAY AROUND THIS BUD THE GARAGE FOOKED IT AND STOLE YOUR MONEY
andz327
Re: loud knocking
Postby transitnewbie26 » Sat Apr 14, 2018 2:21 am
whats the average cost of rebuild or 2nd hand engine? iv spoken to the mechanic its not cam bearing he said its crank bearing and replacement will be 600-700 pounds and 1 weeks work. he said 100% not a rebuild or replacement. Is there anyone in Essex who could look at my poorly van?
transitnewbie26
Re: loud knocking
Postby paul2012 » Mon Apr 16, 2018 4:36 pm
Rebored to 0.5 oversize
4x oversize pistons with rings etc.
Full top gasket set
Full bottom gasket set.
Head bolts
Mains STD shells
BE STD shells
Oil pump
Timing chain kit + cover
Oil Gallery Filter
Parts Price including rebore £745
Engine rebuilds I do myself. 8)
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Re: loud knocking
Postby transitnewbie26 » Tue Apr 17, 2018 12:00 am
iv now been told the clicking could be big end/small end bearing or injector those are two separate garages but both said best bet rebuild anyone who can do it??
transitnewbie26
Re: loud knocking
Postby Jim Archer » Thu Apr 19, 2018 12:32 pm
Going to be a bloody expensive alternative to £40 worth of injector seals ........
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
