throtle pedal help any body here works for fords
Postby ABA » Fri Apr 13, 2018 7:15 pm
purchased a mk 6 2 lt diesal transit just over 3 years ago run fine but throttle pedal started to stick on at about 2000 reves so purchased a brand new one from sandicliffs costs about £ 140.00 that was 2 years ago thing is the new one has started so stick at the same reves and I have to keep sticking my foot under the pedal and lifting it up to get the reves to drop down to normal surley should last more than 2 years and do fords give a guarantee and for how long is it 12 months like every body else thing is apart from the throttle pedal runs just fine but don't want to have to change it every 2 years bit expensive after awhile
ABA
Re: throtle pedal help any body here works for fords
Postby bigjohnthomas » Fri Apr 13, 2018 8:03 pm
It's the copper track that fookes up
Your pressing it too much
bigjohnthomas
Postby andz327 » Fri Apr 13, 2018 9:35 pm
Muddy builders feet can fook them up with lots of cement dust, sand an sh*t and dampness
andz327
Postby bigjohnthomas » Fri Apr 13, 2018 9:40 pm
Jellies can cause premature failure too
What you need is a fashionable pair of Cuban heels the pedal will last for years 8)
bigjohnthomas
Postby andz327 » Fri Apr 13, 2018 9:53 pm
bigjohnthomas wrote:Jellies can cause premature failure too
Premature what ?? oops
andz327
Postby knobby1 » Fri Apr 13, 2018 11:25 pm
bigjohnthomas wrote:What you need is a fashionable pair of Cuban heels the pedal will last for years 8)
I find my 6" Stilettos work nicely...the long heel keeps your foot level with the pedal. :wink:
Postby ned » Fri Apr 13, 2018 11:28 pm
Are they red and sparkly? :wink: N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby knobby1 » Fri Apr 13, 2018 11:32 pm
ned wrote:Are they red and sparkly? :wink: N
Not on your life...red & sparkly indeed... :wink:
Postby andz327 » Sat Apr 14, 2018 2:42 am
Thats when cruise control is yer best friend
andz327
Postby ABA » Mon May 28, 2018 11:19 am
bigjohnthomas wrote:It's the copper track that fookes up
no copper track its 2 black carbon tracks and carnt evan see any wear marks on it
ABA
Postby APH » Tue Jun 05, 2018 10:49 pm
If it is just sticking, you could try lubricating the plastic spindle. however, the plastic wears quite badly over time, due to the force being applied through it, (as you will have discovered, there is quite a hefty spring pushing back against the movement to make it feel like its actually attached to something when you press it) most common fault is momentary disconnection of the wipers from the carbon track, causing one of the three circuits to go open momentarily, its rare they just stick.
damage to the spindle and excessive side to side play can result from feet being hooked under the pedal forcing it up slightly (usually while people sit in the van eating sandwiches etc, resting feet under the pedals rather than on them, or resting beside the pedal on the whee larch pushing it slightly sideways... or as others suggested, just general dirt ingress.
They can be bought for about £60 online, and iv'e never had a problem with the cheaper ones lasting any less time. the one I change on my own van was 6 years ago and still working fine.
Andy :D
(\__/)
(")_(")
this is bunny
APH
Postby ABA » Wed Jun 06, 2018 12:04 pm
tryed lubricating just seemed to make it worse ended up byeing one of ebay about £ 80 sapposed to be brand new working fine at the momment will just have to wait and see
pitty you carn bye just the white triangle where the wires are pluged in there are only 3 plastic clips holding it in place cut off the clips and and prise it off with a screew driver then there would be no need to purchase the compleat pedal assembaly it takes litteraly 3 minns to swap them over i just dont want to have to bye a new one every 2/3 years i only do about 4000 miles a year
ABA
Postby bigjohnthomas » Wed Jun 06, 2018 4:10 pm
I'll sell you the plastic triangle bit :)
90 quid
It will have to be cash though
My card machine has stopped working :o
This one's going straight in the back pocket wink
bigjohnthomas
Postby bambi mk 1 » Wed Jun 06, 2018 7:51 pm
bigjohnthomas wrote:I'll sell you the plastic triangle bit :)
90 quid
More like a pink triangle :lol: :lol:
bambi mk 1
