Recall security update
Postby Smnspark » Tue Apr 24, 2018 6:52 am
After having security up on odb port once vehicle is turned off I have no parking lights spoke to ford who say they haven’t had this problem before I noticed one other person on here has had the issue just wondering has any one else had problems after update
Cheers all
Smnspark
Re: Recall security update
Postby loot » Tue Apr 24, 2018 7:32 am
Take it back to the place that did the security update and they should check it, either install the original asbuilt to see if that foxes it or if it is just a matter of turning the feature you are missing back on in configuration with ids then fairly straightforward.
If software caused the fault then software will fix it :wink:
Ids map here
loot
Postby Smnspark » Thu Apr 26, 2018 6:39 pm
Aparently like iPhones they can’t wind back and update I’m going down to the dealers on Monday to try and get this sorted
Smnspark
Postby Smnspark » Mon Apr 30, 2018 3:02 pm
Now it seems could be a faulty body control module
Smnspark
Postby Smnspark » Thu May 10, 2018 2:54 pm
Ford have now had the van for 2 days they put a replacement body control module in all the lights worked fine they then went to programs it to vehicle and lights stopped working main ford head office is saying that some thing I’ve added to the van is conflicting with the soft ware
Has any one else had any issues with this it’s a custom sport 155ps 2013
Smnspark
Postby loot » Thu May 10, 2018 3:00 pm
Only thing I can think of is either ply lining fitted or faulty tow wiring.
Ids map here
loot
Postby Smnspark » Thu May 10, 2018 8:32 pm
Just picked my van up still no joy with the parking lights for hq have now acknowledged that they have had a few reports of the up dates sodding the lights up apparently when the lock up date is activated through the soft ware it turns a section of the body control module off which also controls the parking lights when the ignition is off
After saying it wasn’t any thing to do with the up date then trying to say it was something that I had added to the van was making the update crash
So they e wasted 3days of my work time 2 days of the garages mechanic time
So if any one else has had this update done check your parking lights when you’ve locked the van ford won’t address the problem until they get so many complaints through there global fault line also they’ve told me that parking lights not working is not part of the mot now which I find hard to believe
Smnspark
