Following on from my DMF question, I have one about this bolt.
I'm not sure if just trying to twist it until it frees is a good idea or if it would be better to cut the bolt head off. If it's stuck on the bush hopefully you could lever the subframe down and then deal with the bolt after. Perhaps I would have to weld a nut onto it.
Has anyone tried this to save ripping the wishbone bush to bits ?
I was going to try and change the clutch etc by just moving the gearbox back but there isn't room even though Ford says there is. I also snapped one of the gear lever tower bolts off in the gearbox which didn't please me much !
