2001 transit van locked out completely
Postby Kirksterno1 » Sat May 05, 2018 10:11 pm
Hi all,
Would someone be able to help me as my 2001 Transit vans doors have completely locked me out.
I was lucky to have a window down when it locked but even the inside won't open.
The central locking appears to have disabled....
I've checked the two 15 amp fuses under the instrument cluster and they were OK.
I've disconnected the battery, hoping for a reset but nothing..
Put wd40 into the locks but nothing...
Taken the door panels off to check but appears to be ok...
The car starts fine but its just all doors...
Also I only have a key for it and no remote...
Any help would be great...
Thankyou
Julian
Kirksterno1
Re: 2001 transit van locked out completely
Postby Frag » Sun May 06, 2018 2:42 pm
Try cycling the ignition on and off 8/10 times,this should put CL module into teach mode,and will cycle the door locks.
Frag
Ford Technician
