2015 transit mk 8
2015 transit mk 8
Postby madmackie » Wed May 09, 2018 11:07 pm
I've just bought a 2015 transit mk8 I think it is apparently it has stop start but it doesn't appear to be working any advice thx in advance
madmackie
Re: 2015 transit mk 8
Postby dumper » Thu May 10, 2018 4:11 am
Have you a switch on the dash to turn it off it’s the top right switch next to Speedo and used to turn it off as it turns on automatically ever time engine is started up personally I don’t like it and allways turn it off on startup
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby madmackie » Thu May 10, 2018 7:26 am
Yes I have the switch to turn it off but it doesn’t seem to work so I can’t turn it off any ideas thx
madmackie
Postby dumper » Thu May 10, 2018 7:57 am
Sorry all I know is it’s automatic maybe blown a fuse it also may not work if lights/ blower motor/air con on also it only works when engine upto temperature try turning every thing off see if that helps
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby Jakm15 » Thu May 10, 2018 12:51 pm
If the batteries not at the right voltage it won’t work, to be honest your better with it not working it’s just annoying.
Engine switches off when you don’t want it too, and in winter the cab goes cold when it goes off.
Jakm15
Postby dumper » Thu May 10, 2018 4:53 pm
X2 been a old git and a control freak they can keep all this sh@t they only put it on so when it goes wrong it has to go into a dealer then trouble is getting someone at the dealership that really no’s his job :D
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby madmackie » Thu May 10, 2018 10:04 pm
Thx all :D :D :D
madmackie
