Heavy power steering on a mk7 14 plate
Postby Gaz transit » Wed May 16, 2018 9:50 pm
Heavy power steering on a 2014 mk7 after replacing power steering bottle ?? Help please
Gaz transit
Re: Heavy power steering on a mk7 14 plate
Postby Frag » Thu May 17, 2018 1:14 pm
Why was bottle replaced ?
Was it ok before this ?
What 'colour / spec' fluid have you used ?
Frag
Ford Technician
Postby Gaz transit » Thu May 17, 2018 8:54 pm
Accident damage
Gaz transit
Postby loot » Fri May 18, 2018 9:51 pm
It's a fairly simple system, pump, pipes, rack.
How damaged was it? Was it fine before? Was it damaged from a crash? If so was the engine cut out from the crash or was it kept running? Is it possible that it stayed running but the pas fluid drained out and the pump ran dry? Or was the bottle cracked into small bits and possibly 1 piece is lodged somewhere causing a flow problem?
There's a story here and pictures may help :P
07 350 170ps
Ids map here
loot
Users browsing this forum: giosoft
