Cruise control problem .
Postby 1robbie » Fri May 18, 2018 4:15 pm
Went to vantuners Strathaven and activated CC . It's activated but doesn't work . The cc light shows on dash when starting the van . Fault code for overvoltage shows on their computer so he thought it might be the switches. Tried another steering wheel , no joy .
Vantuners says he only activates it but doesn't get into troubleshooting so he really doesn't know what the problem is .
I seem to remember reading something about having to program two keys but I only had one with me . Could it be that simple why it won't work .
Any ideas would be appreciated as I have spent almost £300 now and still don't have CC .
1robbie
Re: Cruise control problem .
Postby andz327 » Fri May 18, 2018 6:01 pm
You need to be driving before it works mate, get up to speed press on then set button ....bobs yer auntie
andz327
Postby 1robbie » Fri May 18, 2018 6:32 pm
Lol.
I did that .
1robbie
Postby andz327 » Fri May 18, 2018 7:03 pm
1robbie wrote:Lol.
I did that .
Don't laugh it happens, Howd it cost you that much, there was fook all to do with keys when mine got done
andz327
Postby 1robbie » Fri May 18, 2018 7:15 pm
Needed a steering wheel and BCM . £150
Then £120 at vantuners .
1robbie
Postby andz327 » Fri May 18, 2018 8:57 pm
1robbie wrote:Needed a steering wheel and BCM . £150
Ouch i thought vantuner was £75. For CC activation, i would have thought if it lights( 3-4 seconds)up when ignition on it should work, any other electrical problems
andz327
Postby 1robbie » Fri May 18, 2018 11:46 pm
No electrical problems at all . It's a mystery . I may end up having to go to a Ford dealer but they are so expensive and who knows if they can help . Might be a waste of money .
1robbie
Postby daraioj » Sat May 19, 2018 12:33 am
1robbie wrote:No electrical problems at all . It's a mystery . I may end up having to go to a Ford dealer but they are so expensive and who knows if they can help . Might be a waste of money .
Could it be something wrong with the wires or connectors between the wheel and the BCM?
Also did you clear the codes? I remember getting some codes too when I activated it.
2010 2.4L RWD 100ps MT75 LWB High Roof
daraioj
Postby 1robbie » Sat May 19, 2018 3:04 pm
I assume that vantuners would take care of that end of things . But I don't know .
1robbie
Postby Hewzey » Thu Dec 19, 2019 8:27 pm
Hi, did you ever get to the bottom of this? I have exactly the same problem after a retrofit cc? Thanks
59 mk7 2.2/115 FWD T280 SWB/lowRoof/6sp/silver/140,000(trend)
09 mk7 2.4/115 RWD T350 LWB/highroof/6sp/white/270,000(engine70,000)
Hewzey
Postby Altransit » Fri Dec 20, 2019 1:06 pm
May be a daft question, but here goes ....................
Do you have the correct BCM for cruise :?:
Re: Hill Start assist sticking on
Postby Airthies » Fri Jan 03, 2020 5:03 am
Altransit wrote:May be a daft question, but here goes ....................
Or (as stated by op he bought a new BCM) have you checked the extra wires are there for the CC?
Two usually required from steering wheel clock spring plug to BCM?
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Sun Jan 05, 2020 9:50 pm
I'm not seeing much info here.
Can you tell us specifically what steps were taken from start to finish including parts and wiring spec.
Then what symptoms you have ie. Obvs no cruise but is the green light coming on then off at start?.
Then any fault code you have?
There's 2 wires going from the steering squib to the bcm and they need to be correct and in the correct pins at the bcm.
I turned cruise on for someone but he had a euro 5 pcm so my ids couldn't initialize it, he had to go to Ford to do it but cruise etc worked.
Is it fixed yet? :P
Ids map here
loot
Postby s99sdh » Fri Jun 19, 2020 1:33 pm
Do you guys know which fuse you pull to restore a cruise control fault? I had bother back in 2016 and pulling the fuse was the fix .... it’s now happened again and I am unsure which one it was . 2015 transit custom ...
s99sdh
Users browsing this forum: metalworker0
