Tyre Load Ratings - any guides please?
Postby firewalker » Tue May 22, 2018 11:08 am
I've searched the forums but not really found the answer to what load rating my tyres should be?
Its a Mk6 LWB RWD T350 DIY campervan carrying up to 6 passengers.
Tyre sizes are 215/75/16.
Would a budget tyres 111 rating suffice?
Thanks in advance,
firewalker
Re: Tyre Load Ratings - any guides please?
Postby andz327 » Tue May 22, 2018 11:54 am
firewalker wrote:I've searched the forums but not really found the answer to what load rating my tyres should be?
Thanks in advance,
Most budget tyres that I've looked at have 114/116 but have seen 113/111 rating on budgets (watch out for retreads, kingpin is one name), so yes 111 are suitable as they have load rating of 1090kgImage
andz327
Postby bigjohnthomas » Tue May 22, 2018 12:27 pm
Check your data plate inside the door it has the axle loads on it
On yes :P
Hummmmmmmmmmmmmmmm baby :D
bigjohnthomas
Postby firewalker » Tue May 22, 2018 2:39 pm
Thanks!
Got new on that are rated at 113/111 - not sure what that means then, but either will do!
firewalker
Postby twin wheel camper » Tue May 22, 2018 5:42 pm
The first is for tyre running on a single wheel axel,the second is when fitted to a twin wheel axel,it knocks off from memory 5% of the load rating when running them twin wheel configuration.
twin wheel camper
