mk6 transit rust issues
Postby hbkhhh » Tue May 22, 2018 3:25 pm
hi Guys
please excuse me if i seem i little dumb but my transit needs the sliding door sill replacing but he said i also need the inner sill aswell i have no idea what the differnce is between the inner and outer sill is also i need to replace the front passenger wheel arch/sill section which i have found as one piece on ebay but on phoning around i have been quoted £1000 to cut out old bits off and weld on knew ones does that sound right with me painting them and buying the panels myself. i have added some pictures to show you what i mean
2000 Mk6 T300
hbkhhh
Re: mk6 transit rust issues
Postby Brains_transit » Tue May 22, 2018 4:55 pm
£1000 sounds like a rip off as you can buy another van for that. Source the panels from eBay or local panel suppliers and remove the old bits yourself then pay a welder something like £20 an hour. The sliding door inner sill is an easy panel to made if you have a folder
Brains_transit
Postby hbkhhh » Tue May 22, 2018 5:30 pm
Brains_transit wrote:£1000 sounds like a rip off as you can buy another van for that. Source the panels from eBay or local panel suppliers and remove the old bits yourself then pay a welder something like £20 an hour. The sliding door inner sill is an easy panel to made if you have a folder
I unfortunately do not have a folder so any chance you have a picture of one so I know what it looks like this is what I've found so far
https://www.ebay.co.uk/itm/272700165712
https://www.ebay.co.uk/itm/272700165722
2000 Mk6 T300
hbkhhh
Postby Brains_transit » Tue May 22, 2018 6:01 pm
I got both driver and passenger front arch panels for £75 the pair so shop around and this is the folder I've used to repair my van https://www.machinemart.co.uk/p/cmf24-s ... al-folder/
Brains_transit
Postby ned » Tue May 22, 2018 6:06 pm
Try dieselhead for the parts you need.
They are in this thread somewhere. N
viewtopic.php?f=5&t=170954#p1452286
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby hbkhhh » Wed May 23, 2018 8:49 am
Brains_transit wrote:I got both driver and passenger front arch panels for £75 the pair so shop around and this is the folder I've used to repair my van https://www.machinemart.co.uk/p/cmf24-s ... al-folder/
Ok cool but I still don't know what the inner sill looks like
2000 Mk6 T300
hbkhhh
Postby Brains_transit » Wed May 23, 2018 10:37 am
Click on the link Ned posted and go to page 3, the slinging door inner sill is near the bottom of the page
Brains_transit
Postby hbkhhh » Wed May 23, 2018 11:10 am
Found it. Thanks is it hard to weld yourself
2000 Mk6 T300
hbkhhh
Postby Brains_transit » Wed May 23, 2018 11:16 am
Welding takes practice and the main issue is finding good metal to weld too
Brains_transit
Postby ned » Wed May 23, 2018 12:42 pm
Aye its not difficult to weld but it takes patience and practice to weld well, a good welding machine is a must. N
ned
Postby Brains_transit » Wed May 23, 2018 1:20 pm
You need a gas mig welder as it helps the weld flow
Brains_transit
Postby mistericeman » Wed May 23, 2018 2:37 pm
As above....
Welding isn't difficult IF you can do it... However the rust you can see is likely to be the tip of the iceberg as, it usually starts inside.
Cut back as far as you NEED to otherwise you'll be doing it again in the near future.
mistericeman
Postby hbkhhh » Thu May 24, 2018 10:25 pm
If I don't have any luck finding a welder I might try doing it myself then
2000 Mk6 T300
hbkhhh
Postby ned » Fri May 25, 2018 12:39 am
The mig welding forum is very good help. N
ned
