MK6 Engine Malfunction but rail pressure correct. Help!
Postby Drive4it » Wed May 23, 2018 12:12 pm
Hi.
I'm no mechanic.
I've got a transit Tourneo minibus 59 plate.
After having an issue I had both pressure sensor and relief valve fitted fitted by a diesel specialist..
But for some reason a fault of p0089 rail pressure won't go away and on starting the engine it shows engine Malfunction light.
Can clear it but soon as starting engine it comes on again.
All perimeters in regards to fuel pressure and voltage etc are reading correct. Rail pressure nominal 23.6MPA and rail pressure sensor voltage 1.36v
Because of the new MOT regulations it won't pass on the light coming up. Very frustrating
Any help would be muchly appreciated
Drive4it
Re: MK6 Engine Malfunction but rail pressure correct. Help!
Postby Brains_transit » Wed May 23, 2018 12:43 pm
2009 is mk7 and You have to perform a learn test with ford ids after fitting the new parts,some pictures are missing but the text is still there viewtopic.php?f=18&t=164180
Brains_transit
Postby Drive4it » Wed May 23, 2018 1:58 pm
Thank you.
So what if an IDS test had been done?
Im unsure what it is or whether they did
Drive4it
Postby Altransit » Thu May 24, 2018 8:30 pm
