14 plate mk7 revs when you press clutch
Postby Gaz transit » Wed May 23, 2018 6:06 pm
My mk7 revs up when clutch pressed is this because of hill start ?? Cheers
Gaz transit
Re: 14 plate mk7 revs when you press clutch
Postby blue estate » Wed May 23, 2018 6:08 pm
No it’s the anti stall software
72plt MG 5 ev estate Battery car
blue estate
Postby Gaz transit » Wed May 23, 2018 6:12 pm
Can it be turned off cheers
Gaz transit
Postby Punto443 » Wed May 23, 2018 6:15 pm
Nope.
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby andz327 » Wed May 23, 2018 6:46 pm
Why switch it off ?? It doesn't do it when your driving and It's perfect for traffic jams , engine ticks over in 3rd gear at 10mph perfect or if slower traffic use 1st or 2nd
andz327
Postby dumper » Wed May 23, 2018 8:09 pm
On my mk8 with the 3.1 diff it’s bad when you are reverseing up hill in a tight place it’s sh@t yourslipping the clutch when there is no need to their is to much computer control that the drive should manage him or her self don’t get me wrong I am not against technology bur some times if you are a capable drive you don’t need the driver aids you need to decide what you need as a driver
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Brains_transit » Wed May 23, 2018 10:09 pm
There must be a switch on the clutch so maybe unplug it and see if it registers a fault code
Brains_transit
Postby dumper » Wed May 23, 2018 11:15 pm
Mine has cruse control so switch has to operate to switch it off to charge gear and cut throttle
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
