Mk6 engine and gearbox into mk4
Postby Phily-b » Fri May 25, 2018 1:43 pm
Hi this year my emissions were not tested on the MOT probably cause of it's age but now I hear that visable smoke will now cause it to fail an MOT soon will that then be an issue with my 1989 mk4 transit motorhome if so what better engine will fit in with not to much messing about
I'm wondering if you can swap the old diesel engine rear wheel drive it is for a mk6 turbo diesel engine and gearbox many thanks for reading my query
Phily-b
Re: Mk6 engine and gearbox into mk4
Postby gotgcoalman » Fri May 25, 2018 2:33 pm
Think it's the newer motors with a DPF fitted that the visible smoke applies to.
Too bloody quiet :shock:
gotgcoalman
Postby Phily-b » Fri May 25, 2018 2:45 pm
gotgcoalman wrote:Think it's the newer motors with a DPF fitted that the visible smoke applies to.
Ok thanks for that info
Sent from my SM-N910F using Tapatalk
Phily-b
Postby dumper » Sat May 26, 2018 7:38 am
I think I’ve read somewhere that if you fit a engine out of a newer vehicle the emissions will be tested to the spec of that engine
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Phily-b » Sat May 26, 2018 1:42 pm
dumper wrote:I think I’ve read somewhere that if you fit a engine out of a newer vehicle the emissions will be tested to the spec of that engine
Sounds like I'm better off with the engine that's in it then maybe try to find out what it's smokes it's not to much smoke seen worse get it serviced may help it
Phily-b
Postby gotgcoalman » Sat May 26, 2018 2:19 pm
what colour is the smoke and when is it the worst?
gotgcoalman
Postby Brains_transit » Sat May 26, 2018 2:57 pm
When I used to floor my mk6 it had black smoke then after I blanked the egr and smashed out the dpf it ran a lot cleaner so it will be interesting to see the results of the new test
Brains_transit
Users browsing this forum: mawman99
