heater problem
heater problem
Postby Andyboylester » Tue May 29, 2018 10:17 pm
Hi, I have a 2009 tourneo 9 seater on which the heater is constantly blowing hot. Can't turn the heat off. The kids are saute'ing in their own juices 'cos there are no windows in the back that open.
The fan works fine. Any ideas?
Andyboylester
Re: heater problem
Postby andz327 » Tue May 29, 2018 11:29 pm
Does it have AC
andz327
Re: heater problem
Postby andz327 » Tue May 29, 2018 11:41 pm
Will probably be this unitImage
andz327
Re: heater problem
Postby Andyboylester » Wed May 30, 2018 11:52 am
Hi, yes, it has A/C. I had to buy a new compressor for it last year as it had siezed, but there is also a hole in one of the pipes so there is no gas in it. The garage said that it woldn't affect anything apart from not having A/C, and Im saving to get the pipe replaced (pricey job).
Andyboylester
Re: heater problem
Postby Andyboylester » Wed May 30, 2018 12:28 pm
andz327 wrote:Will probably be this unitImage
Ahh...That looks a likely suspect. Thanks.
Andyboylester
Re: heater problem
Postby andz327 » Wed May 30, 2018 12:35 pm
As a temp fix .... If you go under bonnet and where heater pipes go thru bulk head youll see a water diverter actuator power by vacum pipe, pull pipe of and put small screw to block pipe and that should divert hot water from heater, had to do same myself
andz327
