mk6 2.0 fwd loud rattle
Postby scottsimmo » Wed May 30, 2018 6:22 pm
hi all, my van has got a loud knocking its a mk6 05 plate 2.0 fwd, ive had people say its the fuel pump but someone else has told me it could be the timing chain jumped it has lost power but doesn't smoke it idles a bit rough but still starts up first time ive changed the fuel filter oil oil filter and air filter.
The injectors were loose but I have tightened them up but still this loud knocking is there any help or advise would be great .
scottsimmo
Re: mk6 2.0 fwd loud rattle
Postby knobby1 » Thu May 31, 2018 3:25 am
Have you had the codes read..??
It's not a TDCi is it..??
Sound like you could have a timing solenoid issue if it's a TDDi.
Postby scottsimmo » Thu May 31, 2018 4:54 am
Thanks for that sorry the codes ive been told are p0149 and p1564, i think its a tddi, the injectors dont have any eletrical connections on them if thst helps, ive spoke to a diesel specilist in tilbury and they reckon it needs a pump, im just trying to find out if it could be other things. Cheers
scottsimmo
Postby knobby1 » Thu May 31, 2018 8:19 am
scottsimmo wrote:Thanks for that sorry the codes ive been told are p0149 and p1564, i think its a tddi, the injectors dont have any eletrical connections on them if thst helps, ive spoke to a diesel specilist in tilbury and they reckon it needs a pump, im just trying to find out if it could be other things. Cheers
Probably a duff timing solenoid....or the wiring to it is not well.
Postby scottsimmo » Thu May 31, 2018 9:13 am
Ok great thanks for that ill have a look and check the wiring, could the timing chain jumping cause the same problems?
scottsimmo
Postby knobby1 » Fri Jun 01, 2018 10:02 am
scottsimmo wrote:Ok great thanks for that ill have a look and check the wiring, could the timing chain jumping cause the same problems?
Your codes point to pump issues... so although possible....probably unlikely.
