Boat with transit engine
Postby 000davesinclair000 » Sat Jun 02, 2018 10:37 pm
Hi guys looking for a bit of help, my dad has a boat with a transit engine now he went to start it the other day And didn’t realise there was a bit of wiring hanging down, this got caught on the pulley and tore it off somewhere, the engine turns over but won’t fire, we have a live and earth that we can’t see where it goes, the fuel filter housing has a 3 pin connector on the bottom And the pins look clean would this make sense ?
I’ll try sticking some pictures on
000davesinclair000
Re: Boat with transit engine
Postby Altransit » Sun Jun 03, 2018 12:44 am
You don't say which Transit engine, but I'm guessing that it's an older, non electronic, non turbo, Di diesel :?:
If that's the case, the only (thin) wire that will stop it starting, is an ignition fed live that goes to the stop solenoid on the back of the injection pump. Without it connected to 12v, the pump can't get any fuel delivered.
The wires to the bottom of the fuel filter are simply for a "water in fuel sensor" and have no impact on the engine starting.
Postby 000davesinclair000 » Sun Jun 03, 2018 8:53 am
Yes diesel non turbo mate, I’ll try putting pictures at the bottom of this post ImageImageImage
000davesinclair000
Postby Chug » Sun Jun 03, 2018 9:28 am
As Al said you only need a live feed to the injection pump stop solenoid on the back of the pump to start the engine and power to the starter motor obviously.
Chug
Postby 000davesinclair000 » Sun Jun 03, 2018 9:40 am
Thanks guys I’ve done a google I take it this is what your talking about Image
000davesinclair000
Postby Altransit » Sun Jun 03, 2018 11:24 am
In your last picture of the engine bay above, the pump is sitting under the air filter, (directly under the clip at 5 o'clock) and there appears to be a thin yellow wire heading in the direction of the stop solenoid, which is directly on the back end of the pump.
You need to check that this is actually connected to said solenoid, and that there is 12v on that terminal when the ignition is on.
If not, try putting 12v on the terminal using a fly lead from the battery, and see if the solenoid clicks (*don't touch this wire on anything else, or it may melt rapidly*)
Postby bambi mk 1 » Sun Jun 03, 2018 7:21 pm
Which pulley did the cable wrap around :?: ,if its the bottom pulley at the front of the engine it might have jumped the timing :wink:
bambi mk 1
Postby 000davesinclair000 » Sun Jun 03, 2018 9:56 pm
Ok cheers guys some useful info I’ll let you know how we get on
000davesinclair000
Postby coonak » Mon Jun 04, 2018 12:53 pm
Have you got a picture of the boat I'd like to see what that engine is pushing about.
98 Hiace
2000 Hiace
2003 125 280 gone injectors!
2010 85 280 gone ULEZ!
....68 105 280 Custom eco blue
coonak
Postby 000davesinclair000 » Tue Jun 05, 2018 9:43 pm
000davesinclair000
