no drive
no drive
Postby hibbo11 » Wed Jun 06, 2018 6:34 pm
Good evening, I have a 2001 transit based camper, single rear wheel, on a recent trip I braked as I went into a layby and the rear o's brake locked and skidded and this happened about 3 or 4 times in about an hour, parked up for the night and drove home steadily the next day, tried to make it do it again the next day but all seemed fine.
Decided to have a look and see if I could find a problem, looked at the ns first but couldn't get the brake drum off so turned the van around and jacked up the o's to find the brake locked and I couldn't turn the wheel at all.
So I thought start it up put in gear to move the drum and see if it releases.......... nothing happened. put in gear let the clutch out nothing got out still in gear ticking over nice ns wheel on the ground o's wheel jacked up nothing moving. The only thing I can think is the half shaft is busted, but could I have driven from Wales like that??????
HELP first of all how can I get the brake drum off. HELP.
graham
Graham
Handcross west sussex
hibbo11
Re: no drive
Postby Mad Husky » Wed Jun 06, 2018 9:31 pm
Don't quote me on this one but if one wheel is off the ground you won't get drive something to do with the diff I could be wrong.
Mad Husky
Re: no drive
Postby hibbo11 » Wed Jun 06, 2018 9:57 pm
I thought the drive went to the side of least resistance and would expect to see the jacked wheel rotating , ....I'm confused.
Graham
hibbo11
Re: no drive
Postby Chug » Thu Jun 07, 2018 9:04 am
Locking rear brakes is often caused by a broken brake spring.
Is the propshaft turning?
Jack up the van so both wheels are off the ground and then turn one wheel, the opposite wheel should turn the other way.
I have known vehicles with a broken half shaft to still drive, but usually acompanied by a grinding or knocking sounds.
Chug
Re: no drive
Postby hibbo11 » Thu Jun 07, 2018 10:21 am
Chuggy wrote:Locking rear brakes is often caused by a broken brake spring.
Thanks for the reply,
Problem is it's in my drive and I can't get to both sides at the same time,
No grinding or other noises and it drove from Wales to Sussex.
Question is how can I get the drum off to look now it won't turn ?
Graham
hibbo11
Re: no drive
Postby hibbo11 » Thu Jun 07, 2018 10:47 am
Update I managed to get the other wheel of the ground and it's turning so it's not as bad as I thought HOWEVER i still can't get the drum off anyone got any ideas ?
Graham
hibbo11
Re: no drive
Postby bigjohnthomas » Thu Jun 07, 2018 11:23 am
A little screwdriver through the hole in the back plate and back the adjuster off
Clicity click. :wink:
bigjohnthomas
Re: no drive
Postby hibbo11 » Thu Jun 07, 2018 12:18 pm
bigjohnthomas wrote:A little screwdriver through the hole in the back plate and back the adjuster off
I think the drum is stuck on the hub not on the shoes because I can turn it, if it was stuck on the Shoes it wouldn't turn correct?
Graham
hibbo11
Re: no drive
Postby bigjohnthomas » Thu Jun 07, 2018 12:32 pm
yus but there will be a lip on the drum too
smash it off couple of draw bolts in it ? then twat it with a large ommer
in
out
in out
them
faster faster faster :P
use your anger youve got to hate it
bigjohnthomas
Re: no drive
Postby hibbo11 » Thu Jun 07, 2018 1:05 pm
bigjohnthomas wrote:yus but there will be a lip on the drum too
in
out
in out
them
Draw bolts ? Can you post a drawing please.
Graham
hibbo11
Re: no drive
Postby bigjohnthomas » Thu Jun 07, 2018 1:30 pm
Not sure if they have them on them :?
Might do
Might not do :?
Just a couple of threaded holes in the drum round abouts where are wheel studs are
I only wash dogs a***holes you know
viewtopic.php?f=5&t=95244
bigjohnthomas
Re: no drive
Postby hibbo11 » Thu Jun 07, 2018 3:09 pm
Well I've done it, thanks for the information those that replied, the answer was heat and a bigger hammer but at 71 years of age there's a limit to the size of hammer you can swing whilst laying under a vehicle :? the problem is a lining has detached from the shoe.
Pleased I can now get on with fixing it :D
Graham
hibbo11
Re: no drive
Postby bigjohnthomas » Thu Jun 07, 2018 3:20 pm
whoooooo hoooooooooo 8) :P
bigjohnthomas
