Mk 7 side door locked open
Postby linda45 » Sun Jun 10, 2018 6:01 pm
hi folks
I've had the usual "I can't unlock the sliding door" problem that has been posted on here before. However, I though that if I fiddled with the latch, added some lube and flipped it about a bit, this may help. However I have managed to close the lock piece with the door open and now I can't shut the side door as the lock is locked shut. Any suggestions please?
thanks
Linda
linda45
Re: Mk 7 side door locked open
Postby goldcoast » Mon Jun 11, 2018 2:10 am
Unlock it by pulling outward on the lug while opening by the handle. You might need a friend to help and a piece of coat hanger wire
2000 Mk 5 RWD 2.5 TDI LWB Manual 5 High Roof White
1997 Mk 5 RWD 2.5 TDI LWB Automatic Mid Roof White
+ previously 2008 Mk7 LWB T350 6 speed High Roof
:lol:
goldcoast
Postby linda45 » Tue Jun 12, 2018 8:32 am
thanks.
I did it through a combination of pulling on the lug, the wire, cleaning the contracts and bridging them with some metal (so it thought it was shut) and then clicking the fob a few times.
.. and got it shut before it got dark.
Linda
linda45
