Where is front jacking point on Mk5 smiley ,bannana engine.
Postby OuterMongolia » Fri Jun 15, 2018 9:27 am
Attempted to jack up front end to change front wheel but all that happened was body got higher and front wheel stayed on ground with the suspension damper becoming more extended .The owners manual is a bit vague and just says place jack under front side member with an arrow point at the front on diagram from the side.Where does the jack actually go ? anyone got a picture?
I have a 1999 MK5 Bannana Engined Transit Campervan
OuterMongolia
Re: Where is front jacking point on Mk5 smiley ,bannana engi
Postby gotgcoalman » Fri Jun 15, 2018 10:28 am
Anywhere solid enough to support the weight :wink:
i usually put the jack under the wishbone if I want a wheel off.
Although that's not really an option if the tyre is flat.
Too bloody quiet :shock:
gotgcoalman
Postby OuterMongolia » Sat Jun 16, 2018 11:05 am
gotgcoalman wrote:Anywhere solid enough to support the weight :wink:
yes the tyre is flat ? what do I do?
OuterMongolia
Postby gotgcoalman » Sat Jun 16, 2018 2:01 pm
1 get air into the tyre quicker than it's coming out to get enough lift for the jack to go under the wishbone.
2 use more than 1 jack.(1 to lift the body so it's raising the suspension enough to get a second jack under the wishbone)
3 use 1 jack under the body/sill and chock using wood blocks to get the desired hight.
Never fun when the wheel is completly flat :cry:
gotgcoalman
Postby bambi mk 1 » Sat Jun 16, 2018 2:21 pm
gotgcoalman wrote::( :( :( :(
Necessity is the mother of invention you know :wink: Drive it up on the spare wheel or the block of wood you should :wink: have under the seat :)
bambi mk 1
Postby gotgcoalman » Sat Jun 16, 2018 2:45 pm
the spare wheel was stolen by the "travellers" and the block of wood is neededd to stop the engine shaking about. :roll:
gotgcoalman
Postby OuterMongolia » Sun Jun 17, 2018 12:58 pm
which bit is the wishbone ,just remind me again! is there a pic?
OuterMongolia
Postby Altransit » Sun Jun 17, 2018 1:23 pm
OuterMongolia wrote:which bit is the wishbone ,just remind me again! is there a pic?
The large plate that connects the wheel hub to the subframe. Try and get a jack anywhere under that. I have a small-ish scissor jack that's perfect for this job, when the trolley jack won't go under, or i drive up onto a 2" thick piece of wood to give it 2" more height to start with :idea:
Postby OuterMongolia » Mon Jun 18, 2018 9:49 pm
How do you know about the travellers? there was never a wooden block in van when I bought it!
OuterMongolia
Postby gotgcoalman » Tue Jun 19, 2018 5:02 pm
The block must have been stolen or never there to begin with.
Think it was an optional extra when the van was new. :?
gotgcoalman
