Modular steels size
Re: Modular steels size
Postby ned » Thu Jun 21, 2018 6:11 pm
I actually wanted modulars but these Weller's came up at a good price locally,
Fitting 225 70 r15 tyres (my wheels are 15" )
If you scroll down the page on the link I posted it explains the et offset, if you have 8j your wheels are 8" wide and are going to protrude the arches :wink: N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby ned » Thu Jun 21, 2018 6:12 pm
The picture of the wheel on the van was so I could get the measurement for the centres. N
ned
Postby Bob2v » Thu Jun 21, 2018 6:13 pm
They look cool these r mine still got 2 b drilled
ned wrote:I actually wanted modulars but these Weller's came up at a good price locally,
Sent from my SM-G950F using Tapatalk
Bob2v
Postby ned » Thu Jun 21, 2018 6:17 pm
8) tyres fitted as well, are they 16's? They will go on the transit studs but the studs won't be centred in the hole hence why the need redrilling, where aboits are you in this big bad world. N
ned
Postby Bob2v » Thu Jun 21, 2018 6:19 pm
ned wrote:8) tyres fitted as well, are they 16's? They will go on the transit studs but the studs won't be centred in the hole hence why the need redrilling, where aboits are you in this big bad world. N
There 5x165.1 I need 5x160 lol 205/55/16 fit like a dream and portsmouth and u ?
Bob2v
Postby ned » Thu Jun 21, 2018 6:21 pm
Me I'm in cheshire, member mutley has a jig for redrilling but he's London way, you can make your own jig, I'll try and find the post. N
ned
Postby Bob2v » Thu Jun 21, 2018 6:22 pm
ned wrote:Me I'm in cheshire, member mutley has a jig for redrilling but he's London way, you can make your own jig, I'll try and find the post. N
Ok m8 cheers
Bob2v
Postby ned » Thu Jun 21, 2018 6:32 pm
I can't find the post now but I did lift this image from it awile ago
Basically the studs bolt to the landrover pcd holes and there are 5 X 3mm holes at the 160 pcd, so you bolt the jig to the wheel and drill through the 3mm hole so you then have a pilot hole in the wheel to drill it at the correct diameter for the transits studs. N
ned
Postby Bob2v » Thu Jun 21, 2018 6:35 pm
ned wrote:I can't find the post now but I did lift this image from it awile ago
Oh I'll look in to that so u puttin arches on the van with the wheels ?
Bob2v
Postby ned » Thu Jun 21, 2018 7:00 pm
For now I'm just going to add a strip of rubber on the arch to keep them legal, once I get a few days off and have decided of I 100% like them then I might either cut the arches and weld in extra steel or get some 4X4 plastic arch extensions.
Just need to have a 65mm hole drilled in the steel centre disc to make them hubcentric for the transit. N
ned
Postby Bob2v » Thu Jun 21, 2018 7:08 pm
ned wrote:For now I'm just going to add a strip of rubber on the arch to keep them legal, once I get a few days off and have decided of I 100% like them then I might either cut the arches and weld in extra steel or get some 4X4 plastic arch extensions.
Just need to have a 90mm hole drilled in the steel centre disc to make them hubcentric for the transit. N
I don't think 1s i got ant as deep as ur 1s ? If mine sticks out I might sale them
Bob2v
Postby ned » Thu Jun 21, 2018 7:18 pm
It'll look mean sticking out :wink: they might not be too bad with 205 tyres on, maybe 10mm wider then the arch which will look pretty 8) N
ned
Postby Bob2v » Thu Jun 21, 2018 7:20 pm
ned wrote:It'll look mean sticking out :wink: they might not be too bad with 205 tyres on, maybe 10mm wider then the arch which will look pretty 8) N
I just hope it ant alot lol it shouldn't really
Bob2v
Postby Jim Archer » Fri Jun 22, 2018 8:21 pm
If you don't want the steering to go all to cock, the new ET must equal the old ET plus 1/2 the tyre bead width increase at the rim. E.g swap standard Transit 6 1/2" in place of 5 1/2" and the ET is 6mm greater to compensate.
If it doesn't the steering geometry will need altering to suit if you don't want odd behaviour and tyre wear.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby Bob2v » Fri Jun 22, 2018 8:22 pm
Jim Archer wrote:If you don't want the steering to go all to cock, the new ET must equal the old ET plus 1/2 the tyre bead width increase at the rim. E.g swap standard Transit 6 1/2" in place of 5 1/2" and the ET is 6mm greater to compensate.
Jim
Mmm I see how it go 4 a while
Bob2v
