ballihoo wrote:Yes used a genuine one.
I thought maybe the hub nut wasn’t torqued enough so have tighten that up. But it still leaks. The only thing I can think is to try again with a cheaper one.
Just hassle and wasted time though.
if it still leaks after changing them you havnt seated the correctly, how did you knock them in ?
idealy you need a big socket to knock them in flush thats the same size as the outer edge
