New engine
Re: New engine
Postby Stuartbrown06 » Fri Jul 13, 2018 7:19 am
Only just put mine back together, cracked piston in n.o 4 cylinder and a hairline crack starting in n.o 3. Changed all 4 so we’ll have to see what happens, aftermarket pistons just looked the same as the original ones but hopefully better quality...
Mines a rwd, the guy that tested/condemned my injectors reckons it’s usually pot 3 or 4 as they get the least cooling due to being at the back so not getting as much air flow and it’s the heat that does them.
All 4 of my injectors failed the insulation resistance test on the piezo so I put 4 new ones in as well.
Stuartbrown06
Re: New engine
Postby Smnspark » Thu Jul 19, 2018 12:11 pm
Well I asked ford very Nicely if they may help with the cost of repairs to engine being using the sales of goods act “unsuitable for purpose” as seems to me it’s a common fault cylinder 3 cracked due to injector under fueling but they just said not interested has any one else come across this issue and help me with some advise please
Smnspark
Re: New engine
Postby Smnspark » Fri Jul 20, 2018 1:24 pm
Injector 3 sent for test seems it’s been under one ting which has caused heat and cracked piston
Smnspark
Re: New engine
Postby paul2012 » Fri Jan 10, 2020 10:33 pm
There was a recall issued for Transit Custom - Injectors assembled incorrectly.
Also a PCM update that effectively reduced fueling to prevent piston damage was issued
There is another BIG issue with Injectors on 2.0 EcoBlue engines (Euro 6 with adblue) - Effecting over 19,000 UK vehicles manufactured in 2019
Batch of faulty injectors resulting in high fuel consumption, reduced engine performance, misfires, poor idle & limp mode
Ford will replace injectors under warranty. Currectly there is NOT enough replacement injectors available.
No vehicle recall will be issued for this fault due to DVSA say's doesn't qualify as a safety issue...
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
