HI I hope someone can help, having read through a lot of posts and web sites, I have repaired the battery on my key fob and have 3v at the terminals ( it was broken away on the - side) but i still can not get the remote to work I have put it back together and even left it in the ignition with engine running to give it a bit of extra charge.
The key works in the door fine and all else seems ok but no remote lock or unlock. I read about the aux battery being flat but I have normal lights on dash when i insert key before starting the engine up so assume it is ok.
could it be a sensor or fuse for the remote unlock?
I have only just got the van and the remote was not working when i got it. Transit 62 plate 350 RWD
be amazing if there is an easy fix without spending loads on new key and programming.
Thanks for any advice or pointers in the right direction.
John
Enjoying the weather :
