Mk6 transmission
Mk6 transmission
Postby Scooby doo » Sat Jul 07, 2018 3:31 pm
I have a t300, basically last week the bolt in the selector dropped out into the box, we retrieved it and put it all back together, though been told this can happen again..been told it’s common but not seen anything on this forum..
I also need to source a bolt and nut to go from the gearbox cradle as the one that was put back in has rounded off, it’s in there but don’t know for how long...
Anyone also know where I can source an egr from as mines blowing quite badly..
Scooby doo
Re: Mk6 transmission
Postby karl » Sat Jul 07, 2018 3:35 pm
put thread lock on the bolt when you put it back :D
just blank egr valve off
karl
Tranny Lover!!!
Postby Scooby doo » Sun Jul 08, 2018 10:42 am
I’m hoping he did put loctite on it,
Regards with the cradle well I’m assuming that’s what it’s called,it’s the bar that stops forwards and backwards movement and bolts into the box, it’s that bolt that’s rounded and I need to know the size to put a nut and bolt through it instead..
Scooby doo
