by dumper » Sun Jul 08, 2018 7:56 pm
If the seats are the same as what is fitted to the mk8 17 seat bus the twin seats are quick release and if you have the rails that are bolted to floor you can maybe bolt the rails to the floor but use strengthening plate under the floor made out of 5mil+ steel pate the difficult part will be positioning the holes in the floor to miss x members and all the pipe work and Sod’s law they wil be above the fuel tank have a good look underneath before you start when I fitted a single seat in a mk3 I used the tie strap mounting holes and made a frame to bolt the seat to and added extra bolt through the floor wear I cude get reinforceing plats under the floor
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
