mk 7 egr removal
mk 7 egr removal
Postby rattybathead » Mon Jul 09, 2018 8:59 am
Hi all. got a mk 7, 2.4, 2007 and I'm trying to get the egr valve off. Upper bolt is very tight but in good nick so I sprayed with wd, but the lower bolt is corroded and a 10mm seems too big. an 8mm seems too small. possibly someone has butchered it in the past. Apart from limited access being a major problem, anyone got any suggestions? Was thinking a bout grinding the head off the bolt if I can get into it. seriously stressing! Ps garage would be a last resort due to finances!
Cheers!
rattybathead
Re: mk 7 egr removal
Postby knobby1 » Mon Jul 09, 2018 12:25 pm
Corrosion is a major issue with these machines, especially in the UK and they're definitely a pain to get at on the 2.4 RWD engines.....if you do eventually get the bolts out, I'd suggest fitting 304 or 316 stainless bolts when the EGR goes back in.
I found removing the inlet manifold gives easier access.
Postby andz327 » Mon Jul 09, 2018 12:34 pm
knobby1 wrote:Corrosion is a major issue with these machines, especially in the UK and they're definitely a pain to get at on the 2.4 RWD engines.....if you do eventually get the bolts out, I'd suggest fitting 304 or 316 stainless bolts when the EGR goes back in.
Poxy RWD hehehe
andz327
Postby bambi mk 1 » Mon Jul 09, 2018 1:39 pm
Wait till you get a Euro 5 to change Knobby :twisted:
bambi mk 1
Postby rattybathead » Mon Jul 09, 2018 3:07 pm
ok, thanks! about to have another look at it!
rattybathead
Postby knobby1 » Tue Jul 10, 2018 1:36 am
bambi mk 1 wrote:Wait till you get a Euro 5 to change Knobby :twisted:
Not this black duck mate....my Euro-4 will do me for now. I don't work on others, mostly just mine or friends trannys...
Postby dirtydog » Tue Jul 10, 2018 9:13 pm
I had a right nightmare changing the egr on my mk7, one bolt head sheared off the other rounded off even though I was only using a 1/4" ratchet
It came out like this in the end
I had to replace the egr pipe in the end as the bolts were just too rusted in it
dirtydog
